Author Topic: 1969 window cranks  (Read 7921 times)
l88z16
1969 window cranks
« on: July 01, 2010, 11:13:34 PM »
I have been told that the nos window cranks are different from what was used on the assembly line in 69.Does anyone know what the difference would be???I do know there is a difference between deluxe and standard interior handles.Thanks
GaryL
  • Marilyn and me
Re: 1969 window cranks
« Reply #1 on: July 08, 2010, 04:06:17 AM »
The older reproductions were bad. The rears did not have enough curvature to miss the stainless trim and the fronts did not stay on very well. The newer ones are very good. Not sure about deluxe vs standard.
Gary
l88z16
« Reply #2 on: July 08, 2010, 04:15:47 PM »
Thanks but I am talking about the nos GM cranks.I have not received any responses so I am thinking maybe there is no difference and they are the same.
bc69
« Reply #3 on: July 19, 2010, 12:45:55 AM »
Not sure of the nos diff, but the deluxe shank is longer to get through the molded door panel.
Brad
RSSS
« Reply #4 on: July 19, 2010, 10:48:59 PM »
I don't know a thing about 69 window cranks, but I do know that nos doesn't mean the same as what came on the car at the factory.  Could be the same, but it doesn't mean it is just because it's nos.
KevinW
« Reply #5 on: July 20, 2010, 10:35:21 AM »
Yes and yes.  Deluxe cranks are different from standards, the curves of the handles are different from front standard, front Deluxe.  rears were the same, but different from the fronts. You have to look at them by casting number on the back. There was some good info on team camaro about casting numbers.  The new correct repros are good ( I bought the standards).  correct curve and they stay on the shaft (so far).  NOS ones could be service replacements or from a different car or year.  Go by the casting number!
l88z16
« Reply #6 on: July 31, 2010, 02:39:27 AM »
Thanks everyone.
