Author Topic: 68 350 SS Fan application  (Read 8203 times)
Oregonjam
  • 68 ss350
« on: June 30, 2010, 05:09:59 PM »
A little help needed. I am missing the fan and clutch for a 1968 350 SS with AC.
I have come across 2 that are available; both sellers claim the same application  as well as claiming part # 3789562 but vary substantially in price. They look the same to me in pictures except one has 5 rivets and the other 4. I have attached a picture of both. The one pictured in the CRG report has 4 rivets as well. Did the rivet count vary?
Does anyone know which fan is correct for my application?
Were part #s stamped on the fans that can be used as verification?
Any help is appreciated,
John
68 07D SS350
John
noschevys
Re: 68 350 SS Fan application
« Reply #1 on: July 01, 2010, 12:51:03 AM »
The correct fan for that car is #3931002 and I believe the clutch fan is 5389475.  The number is stamped on the fan blade along with the date code (ex: G68   =July 1968)
Pacecarjeff
    • pacecarjeff.com
« Reply #2 on: July 01, 2010, 02:41:02 AM »
Yes - A/C cars used the 7 blade 1002
« Reply #3 on: July 01, 2010, 04:34:32 AM »
I've definitely seen both 562 and 1002 fans on 68 AC cars.
http://www.camaros.org/coolingsystems.shtml#fan
Sorry, I don't remember the rivet counts though.....
Marty
« Reply #4 on: July 01, 2010, 04:48:02 AM »
The 5 blade fans I have taken off 68 full size cars had 4 flat rivets.
Martin
Martin Foltz
CRG Member
68 Van Nuys Camaro
Pacecarjeff
    • pacecarjeff.com
« Reply #5 on: July 01, 2010, 11:43:05 PM »
Actually that's right. The 1002 fan had limited usage on the Camaros.
I wonder why? They were VERY common on the big cars - Chevelle and Impala.
Why would GM choose to use a 5 blade on A/C Camaros, yet go with a 7 blade on other models?
68rs327conv
    • The build
« Reply #6 on: July 02, 2010, 03:06:26 AM »
In researching my car and others on ebay, it looks like the 68 camaro with the base 327/210hp AC cars used the 1002 7 blade fan but came with the 21" smaller radiator.  The other Camaro AC cars appeared to use the 23" larger radiator but I have not researched those fan applications.  Wondering if the smaller radiator usage in these cars was offset by the 7 blade fan.
68 RS Conv 327/210hp, Powerglide Factory AC
Oregonjam
  • 68 ss350
« Reply #7 on: July 02, 2010, 09:44:47 PM »
Thanks for the support. I have found that the 4 rivets are the ones I see on 68s. I also found it interesting that in my original service manual it shows a photograph of a five rivet setup. That threw in a bit of second guessing for me.
It appears that there is still no consensus or resolution to when and why the 1002, 7 blade fans were used. I found a June date stamped 7 blade fan for 68. Does anyone know when the date stamps and part #s began on fans? My build was 07D and I am currently planning on using this fan. Any thoughts on this?
John
68 07D SS350
John
