Author Topic: what is the correct type of oil filler tube cap ? "S rivet" or "engine oil fill"  (Read 5216 times)
malley67
hi guys,
what is the correct type of oil filler tube cap that came out on a 1968 327/210 hp ? is it the "S rivet" type or the type that says "engine oil fill" on top ? please remember that this is for the oil filler tube, not the one for the valve covers.
thanks heaps guys,
cheers,
rohan  ???
Marty
I took one off a 68 Chevelle 2-BBL engine built in Tonawanda years ago. It was stamped ENGINE OIL FILL AC-FC60.
Hope this helps.
Martin
Martin Foltz
CRG Member
68 Van Nuys Camaro
Pacecarjeff
    • pacecarjeff.com
FC60 was used a bit later.
The FC2 was used in 68.
However both types FC or S would be correct, but the FC2 oil cap is much more common for 68.
