For '68 Camaro, there's two fibers each side at the front, one for headlamp and the other for park/indicator lamp.
The 3 rear ones are for L + R tail/stop and number plate lamp.
but if you notice in the pix of the front guards, one of them has just 2 lights ( green and clear )
Not correct, top and bottom pics are of the same car [different locations] with 3 lenses in left and right. Your middle pic is not clear, if you blow it up you can see the middle lens in that one too. [same car still???]
If you check the 69 assembly manual, U46 A2 page 425, you will see only 2 fiber optics for the front. You cannot have three since the high beam and low beam are the same bulb.
yep, though strictly speaking, it's not a hi/lo beam situation, it's 1 or 2 headlights [for the benefit of others]
Is it an LA built car? The factory in LA would have both 2 and 3 lense front monitors on hand, so its possible someone grabbed one intended for a car with 4 headlamps. Norwood would not have any 3 lamp monitors on hand since all they made in 68 was Camaros. Might be possible in late 69 at Norwood after April when the firebirds were being made there since they habe 4 headlamps and would need a lens monitor (assuming it was an option on the FBs)
Unfortunately, what's on my dec '67 built car throws a spanner in this theory.
It has the 3 lenses [green, clear, clear] and is a Norwood car.
Also, I know it's an assembly for a 2 fiber per side vehicle because the rubber mount inside the guard bezel that the lens and fibers sit in, has the inner clear position blanked off at the lens end and has no slits in the rubber in that cavity for a ferrule rim to engage into.
I've never seen a Camaro monitor without the middle lens.
