Author Topic: 67 crossmember to subframe mounting hardware  (Read 11735 times)
Re: 67 crossmember to subframe mounting hardware
« Reply #15 on: August 17, 2012, 03:47:51 PM »
I posted mine as 9/16-16. I'm not up on the correct syntax for bolt identifications.
Bolts are identified by their thread diameter and pitch, and length from the bottom of the head to the end of the bolt; i.e., 3/8"-16 x 1-1/4". Standard 3/8" bolts have a 9/16" hex head, but that's not used in describing the bolt.
