Author Topic: '69 Radiator questions  (Read 6594 times)
Dave69x33
« on: May 25, 2010, 10:40:50 PM »
Fan Shroud Clips:
Based on the '69 Assembly Instruction Manual (AIM), Section UPC 11, page 147 covering the original installation of the radiator and related components, I assume the fan shroud clips were not painted, and originally black/dark gray phosphate plated?
I also base my assumption from the attached picture I took of an original survivor '69Z "UH" code radiator.
Overflow hose clip:
Was the overflow hose retained with a clip (like the repro "BC" code clip sold by Heartbeat City, Item EGP-2111), or did the side tank have a stamped-in hose retainer?  The attached picture shows the clip but it is not called out as a separate detail part number in the AIM.
Correct drain cock:
Can anyone confirm who sells the correct drain cock with the "ears" pointing toward the engine?
Painted radiator ID tag:
If recall correctly, that tag was added to the side tank before the radiator was painted and thus painted along with the radiator.
Thanks in advance for your help!
Re: '69 Radiator questions
« Reply #1 on: May 26, 2010, 04:35:51 PM »
The shroud clips were phosphated, and the overflow hose clip was part of the radiator assemblly as received from Harrison.
Camaro Billy
    • 1969 RS/SS
« Reply #2 on: May 27, 2010, 12:59:52 AM »
Here is the only correct looking petcock I know of.
http://www.danchuk.com/ItemForm.aspx?item=400
It looks good with the hose off
Billy
1969 RS/SS 350/300 Rallye Green . Black Vinyl Top
Dave69x33
« Reply #3 on: May 27, 2010, 11:10:13 PM »
Camaro Billy,
I'll give Danchuk a call...thanks.
JohnZ,
Do you still have your original radiator in your car, and is the rad overflow hose clip painted?
« Reply #4 on: May 28, 2010, 01:55:58 PM »
JohnZ,
Yes, it has the original "UH" radiator, and the clip appears to have been painted with the radiator.
