Author Topic: Is there report for finding Date Codes?  (Read 6952 times)
MyRed67
  • SZZLN 67
« on: April 28, 2010, 06:21:01 PM »
  Does anyone know of a publication or report for finding Body panel Date Codes?
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
Re: Is there report for finding Date Codes?
« Reply #1 on: April 29, 2010, 06:05:14 PM »
This is the only reference I've seen published:
http://www.camaros.org/numbers.shtml#sheet
Just about every stamping on the car has a date code or "run number" on it somewhere.
tmodel66
« Reply #2 on: April 29, 2010, 06:20:37 PM »
MyRed67     I am hunting the same information. If I find something I'll let you know. I know where the hood,valance, and frame horn is but that's about it.
MyRed67
  • SZZLN 67
« Reply #3 on: April 30, 2010, 02:29:22 AM »
  Was your car built in '66?  Mine is an 11A - LOS build.  I have found the Doors, Trunk, Fuel Pipe Cover and Rear Quarters.  Doors is top center right where Body color and Int. color meet.   Trunk lid is center Front Re-enforcement.  Fuel Pipe cover is center underside. Rear Quarters is in the corner near the Trunk lid hinge. Right now I'm looking for the Hood and front Fender Date Codes.  Can you explain where the Hood date Code is located?  Or maybe even post a Picture?   Thanks!
1967 Camaro  LOS  11A
MyRed67
  • SZZLN 67
« Reply #4 on: April 30, 2010, 05:49:55 AM »
  Sorry picture was too large, here it is.
1967 Camaro  LOS  11A
MyRed67
  • SZZLN 67
« Reply #5 on: April 30, 2010, 03:29:59 PM »
tmodel66:
Sorry, I guess the first post with the above picture didn't go through. (picture was too large)  Anyhow, I just found the Firewall Date Code last night(H42R).    It is under the Heater Motor Box, mine was partially covered by the caulk.  The other # is your partial VIN., (should match the 2 nd. half of the VIN. # on your title.  Good Luck!
1967 Camaro  LOS  11A
tmodel66
« Reply #6 on: April 30, 2010, 05:05:27 PM »
My Red 67Yes it came thru. My friend has the 67 02D. I helped him build it years ago when all these numbers weren't important. We had to fix the left frontend where he lost it and hit a guard rail.The hood should be stamped on the outer edge on the driver side.  The frame horn is on the out side driver side also toward the front of it. If I remember correctly the valance is stamped kinda in the middle underside.
MyRed67
  • SZZLN 67
« Reply #7 on: April 30, 2010, 11:50:16 PM »
  tmodel66:
  Thanks for info. on Hood stamp, I'm going to try to get over where it's stored and look at it(and front fenders) tomorrow.  This report posted above helped me find the Firewall Code.  And the picture on there I think is going to help me find the Fender Codes(I'm hoping).  I'll post anything I find.
1967 Camaro  LOS  11A
MyRed67
  • SZZLN 67
« Reply #8 on: May 22, 2010, 04:35:16 AM »
tmodel66:
I tried to post reply a couple times lately, it didn't post.  So I'll try again.  I did find Date codes on both Front fenders they are near where the Radiator Support bolts to the fender(same on both sides).   I found 1 on the Driver Side very rear corner of the Hood.  I also found 1 on the Crossmember(brace) behind the Rear Seat.  And I found several around the inside top brace, I have the Headliner tore out to replace so these were easy to find.  1 was in center above Rear Window, 1 on each side above Drivers and Pass. head, and 1 on the front brace was near where the Pass. Sunvisor attached.   If you send me an e-mail address I can send you all the pictures.
1967 Camaro  LOS  11A
