Author Topic: Early 67 L48 engine details  (Read 5565 times)
Petes L48
« on: April 28, 2010, 04:46:26 PM »
Newbie here, please excuse if these have appeared earlier.  Car is RS/SS conv w/ air, 11/11/66 LOS build date
For the script chrome valve covers, on which side does the one with two wire tabs go, and what do the tabs hold?  I don't see this detail in the AIM.
Oil filler tube, chrome or black?  Car is closed element if that matters.  I have a NOS Z28 3889316 tube bought several years ago, but AIM lists a different part #.  Seems like the repop suppliers are pushing  chrome Z28 version as a correct tube.
For the crankcase vent tube, the AIM shows hose 3883966 and a tower clamp used to connect the tube to the air cleaner bottom tube.  Is this available anywhere, or is their a suitable alternative?
Lastly, did the Powerglide use a 14in 168 tooth or 12.75in 153 tooth flexplate?  My car is in storage a couple states away and I wanted to order a new one in advance for replacement during an engine swap.  Never had it apart before.
plumL78
Re: Early 67 L48 engine details
« Reply #1 on: April 28, 2010, 07:04:16 PM »
It goes on the driver's side and the tabs are for the temp. sender  wire .
Petes L48
« Reply #2 on: April 29, 2010, 01:33:44 PM »
Been awhile since I've done anything on the car, forgot about that one.  Thanks.
