Author Topic: Front Swaybar  (Read 35906 times)
L22K19
Front Swaybar
« on: April 25, 2010, 12:07:50 PM »
I have just noticed that my early 67 six cylinder car has no front sway bar fitted. From what I can see of the bounting bracket holes in the subframe have never had a bolt fitted to them. Is this a common thing?
Al
77thor
Re: Front Swaybar
« Reply #1 on: April 25, 2010, 03:05:26 PM »
I thought that all Camaro's came from the factory with a front swaybar...
but I'm no expert... still learning.
The real experts will chime in.
67ss350camaro
Re: Front Swaybar
« Reply #2 on: November 11, 2010, 08:40:00 PM »
Yes, I have noticed this before.  I assume that your car is an L22 by your user name?
67 RS/SS 350 auto (owned since 81.)
97 V6 5-speed Coupe (work car ordered new)
2012 1LS (V6 6-speed) Coupe (new work car)
My Camaro
67conv6cyl
Re: Front Swaybar
« Reply #3 on: February 23, 2012, 11:52:07 PM »
My 67 convertible 250 6cyl came with factory sway bar
Re: Front Swaybar
« Reply #4 on: March 02, 2012, 08:39:42 AM »
Chuck's real early 08D L22 (250) also doesn't have a sway bar.
What's the build dates of your cars?
67conv6cyl
Re: Front Swaybar
« Reply #5 on: March 06, 2012, 04:17:40 AM »
build date for my 250 is 04A has factory sway bar.
L22K19
Re: Front Swaybar
« Reply #6 on: September 23, 2012, 12:04:55 AM »
My car is 02A and is a LA built car. I have since purchased a 6cyl Convertible that is 03C and it has a sway bar.
deputystoneman
Re: Front Swaybar
« Reply #7 on: January 27, 2013, 01:10:40 AM »
The bushingsn
 are rotting on the front sway bar of my 68.
What size sway bar and brand is best for replacement of the entire thing.
Re: Front Swaybar
« Reply #8 on: February 06, 2013, 01:30:55 PM »
So, sorting things like I always do.....
     plant eng swaybar
08D LOS 250  no
02A LOS 250  no
03C               yes
04A        250  yes
I have to say this is surprising. GM said only the 230 didn't have the swaybar in 67.
The swaybar bushings are readily available from most suppliers in rubber (original) and urethane.
67conv6cyl
Re: Front Swaybar
« Reply #9 on: February 07, 2013, 10:35:16 PM »
May be all convertibles got swaybar?
Re: Front Swaybar
« Reply #10 on: February 08, 2013, 05:57:11 PM »
Good point. I tend to think it didn't depend on body type, but I have no idea. Adding that into the mix shows we really need more data. :)
      plant eng      swaybar
08D  LOS 250 cpe  no
02A  LOS 250        no
03C               cvt  yes
04A  NOR 250 cvt  yes
*updated*
« Last Edit: February 11, 2013, 05:44:35 AM by KurtS »
67conv6cyl
Re: Front Swaybar
« Reply #11 on: February 08, 2013, 08:55:49 PM »
My 04A cvt was NOR built, just to add more data
Daytona Yellow 69 Z/28
Re: Front Swaybar
« Reply #12 on: August 08, 2016, 08:08:57 PM »
Just to add to the list..
08E Nor L6 Coupe no sway bar
Re: Front Swaybar
« Reply #13 on: August 08, 2016, 10:04:19 PM »
       plant  eng           swaybar
08A  NOR  ??  coupe    no
08D  LOS 250 coupe    no
08E  NOR  ??  coupe    no
02A  LOS 250              no
03C                 convt    yes
04A  NOR 250 convt    yes
05D  NOR 230 coupe   yes
I added some more data. Not a lot to go on, but it looks like it could be a time-based change.
AZ67Camaro
Re: Front Swaybar
« Reply #14 on: September 20, 2022, 06:24:01 PM »
Just add to the list.
05C NOR CVT 250 with sway bar (11/16")
