Author Topic: Steering column problem  (Read 4949 times)
emanuelK
« on: April 20, 2010, 04:40:53 AM »
After winters restoration having lots of job done on the car I realized now from driving the car that the steering is very unpleasent. It feels like it binds in at least 2-3 positions when turning the steering wheel. I checked on the problem by release the two bolts connecting the rag-joint and the it felt much better. I tried to tighten the bolts again in a slighter different position but the problem occurs again.
It can be said that I replaced my body bushings this winter with new ones in polyurethane which may caused this problem. But, if I remember well I felt this (not so much) also earlier. I read that the steering column can be re-aligned to solve the problem. How is this done??
The car is a 1967 camaro conv. with power steering.
Thanks /Emanuel
Re: Steering column problem
« Reply #1 on: April 20, 2010, 01:48:06 PM »
Loosen all the column and toe plate attachments and follow the mandatory assembly sequence shown in detail in the Assembly Manual in UPC 9, sheet A6 to re-align the column without stresses.
emanuelK
« Reply #2 on: April 20, 2010, 08:31:32 PM »
Thanks John. A good start is maybe to buy the manual. /Emanuel
