Author Topic: 67 Header panel Date code stamp  (Read 4616 times)
MyRed67
  • SZZLN 67
« on: April 19, 2010, 12:03:12 AM »
  Can someone tell me approximately where to look for the date code stamp on a 67 Header panel?  I'm pretty sure it is the original, but it is really Heavy surface rust on the underside.  I think I read somewhere that the underside of the Header Panel was Bare metal from the factory, which would explain why mine is so rusty.  Any help is much appreciated!  Thanks!
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
Re: 67 Header panel Date code stamp
« Reply #1 on: April 19, 2010, 02:18:33 PM »
It's on the return flange at the front of the panel, about 6" toward the passenger side from center, between the two pierced holes; photos below. The panel wasn't bare metal from the factory - it was flow-coat/dip-primed on all surfaces and baked before it was color-coated.
MyRed67
  • SZZLN 67
« Reply #2 on: April 20, 2010, 04:42:27 PM »
 Thanks John, I found a partial 4.  All other date codes that I have found are 42 or 43. I'm assuming the car was built around 45 (1 st. week of Nov.)
1967 Camaro  LOS  11A
