Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
John Z vacuum seyup
« previous
next »
Print
Pages:
1
2
All
Author
Topic: John Z vacuum seyup (Read 20919 times)
fireZ
Hero Member
Re: John Z vacuum seyup
Reply #15 on:
April 19, 2010, 12:36:38 AM »
I will go to the local GM dealer tomorrow and see what I can find out. Thanks for everyones help
Logged
1968 Z28 LA Built
LIC # RPO Z28
L78 steve
Hero Member
Reply #16 on:
April 19, 2010, 04:54:34 PM »
From what I've been told the B28 can has been discontinued for some time. You will have to call around with the numbers supplied in this post to try to find one in stock somewhere.
Logged
69 Z/28 Dover White. SOLD
fireZ
Hero Member
Reply #17 on:
April 19, 2010, 09:22:18 PM »
Called around and cannot seem to find a B28 canister. My car has a B16 now and with Johns vacuum setup the car is a lot more streetable for cruising. Thanks all Paul B
Logged
1968 Z28 LA Built
LIC # RPO Z28
Hero Member
Reply #18 on:
April 20, 2010, 01:32:08 AM »
GM Parts Direct has them, I ran the number John posted and it's in stock. So does the other link I posted. So if you want one you can get one. Calling around will not prove successful. My supplier can't get one either.
Last Edit: April 20, 2010, 01:57:28 AM by Sauron327
Logged
fireZ
Hero Member
Reply #19 on:
April 20, 2010, 12:02:01 PM »
Called GM anough at 12 dollars they are only available in the States. It will take 10 days to get a couple shipped up to Canada. Seem cheap en
Logged
1968 Z28 LA Built
LIC # RPO Z28
L78 steve
Hero Member
Reply #20 on:
April 20, 2010, 12:47:17 PM »
Get the B28 if you can. They are ideal for High perf. low vac. engines.
Logged
CRG Member
Reply #21 on:
April 20, 2010, 01:51:23 PM »
I buy them six at a time from GMPartsDirect.com for $6.50 each.
Logged
fireZ
Hero Member
Reply #22 on:
April 23, 2010, 12:55:07 AM »
I was able to drive across the border today and buy a couple B28 cannisters. Installing it tonight.
Logged
1968 Z28 LA Built
LIC # RPO Z28
ibfootin
Member
Reply #23 on:
May 29, 2010, 09:22:24 PM »
How do I open the pictures on reply #1
Logged
CRG Member
Reply #24 on:
May 30, 2010, 02:57:44 PM »
<<How do I open the pictures on reply #1>>
They must have disappeared when the site was hacked - here they are again; this is the factory setup.
Logged
CRG Member
Reply #25 on:
May 30, 2010, 03:01:57 PM »
Here's the second photo of the "driving" setup, with the distributor vacuum advance line connected to the tee in the choke pull-off hose where the diverter valve signal hose was connected on the factory setup.
Logged
ibfootin
Member
Reply #26 on:
May 30, 2010, 11:32:03 PM »
Thanks John
Logged
fireZ
Hero Member
Reply #27 on:
May 31, 2010, 12:45:17 AM »
I did this setup on my 68 Z and I must say it was the best thing I have done for the car. It is crazy how much nicer the 302 is to drive just by changing the canister and doing Johns vacuum setup . It takes five minutes but what a improvement for the street.
Logged
1968 Z28 LA Built
LIC # RPO Z28
Print
Pages:
1
2
All
« previous
next »
Maintenance
John Z vacuum seyup
