Author Topic: DZ Distributor  (Read 4826 times)
montgomg
DZ Distributor
« on: April 06, 2010, 02:25:28 AM »
How difficult is it to come up with a 532 CCW advance cam for the 1111480 distributor? What other GM distributors was this long slot advance cam used in?  Thanks.
Re: DZ Distributor
« Reply #1 on: April 06, 2010, 10:32:46 PM »
I've seen them on ebay lots of times and fairly cheap $20 or so.
jonboy1216
Re: DZ Distributor
« Reply #2 on: April 07, 2010, 12:17:26 AM »
ive seen for 75.00 or so
Jerry@CHP
Re: DZ Distributor
« Reply #3 on: April 07, 2010, 06:30:15 PM »
I think the 1111482 dist had that cam, and there's another that does too.  You do not need that cam to make the dist work correctly.  It's actually better with a shorter slot as shortening the curve is where the engines are really happy and run better.  Especially the 302.  I have special over size advance bushings that I use in my dist rebuilds to make the curve shorter with stock 532 and 732 cams.
Jerry
