Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Mild Modifications
3" exhaust systems
« previous
next »
Print
Pages: [
1
Author
Topic: 3" exhaust systems (Read 10085 times)
william1
Member
3" exhaust systems
on:
April 01, 2010, 03:03:58 PM »
i need to update the exhaust on my 69z, i have been looking at the magnaflow 3" SS systems with the X pipe, but the more i look around the more confused i get, 2".5 or 3", stock look or not, etc, originality is not the main thing for this one, just a nice solid performance good sounding system, any help on this would be appreciated..
Tweet
Logged
CRG Member
Re: 3" exhaust systems
Reply #1 on:
April 01, 2010, 03:29:58 PM »
A 3" exhaust system (with all its fit and clearance issues) may be great for "bling" on cruise night, but it's a waste of money; exhaust gases cool VERY rapidly before they ever get to the mufflers, and their density and velocity go WAY down in a hurry. A street engine doesn't need a 3" exhaust system.
Logged
hydromo
Newbie
Reply #2 on:
April 03, 2010, 06:13:18 AM »
I have a ZZ427 crate engine headers built by Dan Lemons and a torque tech exhaust system 3 inch works great
Logged
77thor
Member
Reply #3 on:
April 03, 2010, 06:31:28 PM »
3 inch pipes are only recommended for over 500 HP engines....
Logged
hotrod68
Hero Member
almost finished
Reply #4 on:
April 04, 2010, 04:26:43 AM »
I know if you uncork a 302 with headers you'll pick up 3-4 tenths at the drag strip, and that's significant. It's a balance of cam, compression, and exhaust gas velocity v/s backpressure. I have a 3" system on my car with a 406 and wouldn't dream of choking that engine with 2-1/2" pipes. But with either size pipes, the most important thing is the pipes being mandrel-bent. A 3" system with conventional bends is no better than a mandrel-bent 2-1/2" system from my experience. My 2 cents and good luck!
Logged
HotRod'68 1968 SS350 coupe undergoing frame-off resto/rod. 386/350/4.11s
Butternut Yellow black standard interior
LB68SS350
Member
Reply #5 on:
April 04, 2010, 06:22:06 AM »
William - I think a 2 1/2" mandrel bent system on your Z would be the way to go. That's what I have on my '68 SS with a 355 (.030" over 350). It sounds great and makes really good power. I concur with JohnZ about losing exhaust velocity with a 3" system. That would KILL your torque, not to mention fitment problems. With the system I bought from Torque Tech, mandrel bent, 2 chamber Flowmasters, all 2 1/2", the car made 385 rear wheel horsepower and 448 rear wheel torque on the chassis dyno. Larry
Logged
william1
Member
Reply #6 on:
April 23, 2010, 01:35:14 PM »
went with the magnaflow 2 1/2" dual,,, sounds great, the fit was no problem, and is solid,, will change a few things next time i have it off the floor, but over all, i'm happy with it, thanks for the info.......
Logged
Print
Pages: [
1
« previous
next »
Mild Modifications
3" exhaust systems
