Author Topic: 15 x 6 YS Code Rally Wheel  (Read 11965 times)
keith k
« on: April 22, 2006, 08:04:38 PM »
I picked up a set of original 14 x 6 Rally Wheels for my '67 today, and got an extra 15 x 6 in the deal.  On the outer rim (would be inside the tire if a tire was on it) it says 15 x 6 JK.  The code by the valve stem appears to be YS, but the S is sort of faint compared to the Y.   The date code on the other side of the valve stem is K19 10.
Also, it's a 5x4-1/2 bolt pattern, and iit seems to have an odd backspacing of 3-1/2".
Does anyone know what this could be?
I found a reference to a YS wheel on the net, but can't find anything that says what application it was for.
keith k
Re: 15 x 6 YS Code Rally Wheel
« Reply #1 on: April 23, 2006, 03:31:51 PM »
With that bolt pattern, it's probably for a Ford or AMC application.
keith k
« Reply #2 on: April 23, 2006, 05:43:59 PM »
Oh -- Then I probably measured it wrong.  It WILL fit on a Camaro -- has same pattern as Camaro/Chevelle.
keith k
keith k
« Reply #3 on: April 23, 2006, 09:51:57 PM »
OK... here are some pics, if that helps.
keith k
« Reply #4 on: April 24, 2006, 01:20:28 AM »
Keith,
"YS" wheels were used on 69 Full Size with Disk Brakes and 70 Full Size (except wagons) with Disk Brakes. The wheel is 15x6 and has an offset of .06"
keith k
« Reply #5 on: April 24, 2006, 02:12:26 AM »
Keith,
Thanks!
Did the full size Chevys use the same bolt pattern as the Camaro and Chevelle then?  For some reason I thought they were different (but maybe I'm thinking of Pontiacs, and Chevys aren't the same).
keith k
« Reply #6 on: April 24, 2006, 03:10:44 AM »
Keith,
Yup. 5 on 4-3/4"
With a few exceptions, Chevrolet has used the same bolt pattern almost forever!
