Author Topic: Original coil bracket bolts  (Read 9344 times)
GaryL
  • Marilyn and me
« on: March 14, 2010, 04:56:54 PM »
What is the head marking on the original/correct bolts?
Gary
Marty
Re: Original coil bracket bolts
« Reply #1 on: March 15, 2010, 02:57:01 AM »
I picked a pair up probably 15 years ago in a junkyard. They are special bolts. The head markings are RBW with 3 concentric circles. The head has a built in washer that slopes down off the hex head. There are also marks of each of the 6 hex head flat spots that go toward the edge of the washer. And it has teeth on the bottom side to grip into the coil bracket. The threaded portion is 0.5" long. Does this make sense? This is for a 68. Anyone else have these on their original 68?
Martin
Martin Foltz
CRG Member
68 Van Nuys Camaro
GaryL
  • Marilyn and me
« Reply #2 on: March 15, 2010, 01:10:05 PM »
I have a '69. The same as a '68?
Gary
Marty
« Reply #3 on: March 16, 2010, 01:24:46 AM »
I don't know for sure. I took these bolts off 68 cars that were not Camaros years ago.
Martin
Martin Foltz
CRG Member
68 Van Nuys Camaro
« Reply #4 on: March 16, 2010, 02:24:37 PM »
Both '68 and '69 used the same coil bracket bolt (3848408), according to the A.I.M.
GaryL
  • Marilyn and me
« Reply #5 on: March 16, 2010, 02:38:48 PM »
Do you have an idea what the head marking is? Thanks.
Gary
« Reply #6 on: March 16, 2010, 10:53:26 PM »
Gary, I'm sure there were many different suppliers for these bolts.  For example, the original coil bracket mounting bolts on my '68 Z/28 have a "T" that bisects the head of the bolt.  I believe this "T" identifies the bolt grade, in this case grade 5.  On the other half of the bolt head is an anchor!
john302
« Reply #7 on: April 23, 2010, 12:55:30 AM »
I have the same tee bolts on all three of my 68z/28.I have also seen E bolts in late 68 and 69 . John
Dave69x33
« Reply #8 on: May 28, 2010, 01:15:37 AM »
This is the coil braket kit AMK Productions sells for about $4.
Ref. amkproducts.com
big iron
« Reply #9 on: May 28, 2010, 02:07:10 AM »
 67 AIM UPC 6 B5 same #.
GaryL
  • Marilyn and me
« Reply #10 on: May 28, 2010, 02:56:38 AM »
I just son't want to end up with Mustang bolts..... ;D
Gary
