Author Topic: Block suffix code and Munci metal tab.  (Read 3956 times)
pjbizjak
« on: March 13, 2010, 12:13:42 AM »
I have a 3932386 block dated I68, with a pad stamp of V0910XK. I believe this is a is a 69 block 350 4 bolt and I think it's a truck block. Can anyone verify my findings? Also on my Munci tranny there's a metal tag attached to the lower left bolt of the cover, and with out removing the bolt to see all the numbers, the numbers 915085 are stamped on it, any ideas?
Re: Block suffix code and Munci metal tab.
« Reply #1 on: March 13, 2010, 01:24:09 AM »
A quick "XK engine suffix code" search on Google shows...  1969 350cid/215hp 2 barrel carbureted V8 used in T-50 & 60 models.
« Reply #2 on: March 13, 2010, 01:33:33 AM »
Your 915085 transmission tag is probably 3915085, same one that's on the Muncie M21 transmission in my '68 Z/28.  Read this CRG thread for more info on the tag...  http://www.camaros.org/forum/index.php?topic=1830.0
