Author Topic: what intake gasket for a 69 Z? with or with out heatriser hole  (Read 9230 times)
svtrich
Im ready to put the manifold on. should I buy a gasket that has no heatriser provisions.I live in California so a choke wont be an issuse.which gasket shold I use?
                     Richard
Re: what intake gasket for a 69 Z? with or with out heatriser hole
« Reply #1 on: March 06, 2010, 11:03:06 PM »
I blocked mine off and live in Oregon.  I haven't had any issues.  It does take a while to warm up when it's cold.
svtrich
« Reply #2 on: March 06, 2010, 11:05:48 PM »
do you remember what gasket  you used
              Rich
Gramps69Z
  • 69 X33 D80
« Reply #3 on: March 06, 2010, 11:12:54 PM »
Previous posts using the advanced search function.
http://www.camaros.org/forum/index.php?topic=6098.0
Captain John Wykoff
svtrich
« Reply #4 on: March 06, 2010, 11:38:43 PM »
that doesnt tell me what gasket I should use
« Reply #5 on: March 07, 2010, 03:14:43 AM »
I used Fel-Pro. The gaskets I had have a little metal piece that goes in the hole to block it off.  Same gasket, you either used the metal block or not.
RamAirDave
    • TheMuscleCarGuys.com
« Reply #6 on: March 07, 2010, 03:50:22 AM »
Fel-Pro also has a black "racing" gasket set that has no holes for the heat crossover.  Don't remember the pn, but it's one off from the blue set.
www.TheMuscleCarGuys.com
« Reply #7 on: March 07, 2010, 03:39:36 PM »
It's a lot easier to reverse if you just wire the heat riser valve open, and the choke will still work.
svtrich
« Reply #8 on: March 07, 2010, 04:11:50 PM »
John
do you know a fel pro part # that you can recommend?
                    Richard
« Reply #9 on: March 08, 2010, 05:31:13 PM »
John
                    Richard
I use Fel-Pro #1256 - has stainless inserts with small round holes at the crossover passage instead of the full open ports.
NED
« Reply #10 on: March 11, 2010, 03:38:28 AM »
Paragon Corvette reproduction parts has the correct gasket set for the 69Z. Same as Corvette with aluminum intake.   Clem
Bill
67Z Bench seat
69JL8 Burnish Brown
67 camaro modified ls1,6 speed, 9 "rear
