Author Topic: who has original type rivited upper ball joints  (Read 11387 times)
svtrich
« on: March 03, 2010, 05:58:54 AM »
same as above
                 Rich
BillG
Re: who has original type rivited upper ball joints
« Reply #1 on: March 05, 2010, 11:26:11 PM »
I still have my original ball joints.  I'm sure many others do too.  They are rivited.
Bill Garrett
another kurt s
« Reply #2 on: March 11, 2010, 02:40:13 AM »
I am also curious where to get original style front end rebuild kits.  I am in the process of rebuilding my subframe and front end and wonder what kit is most original.  any suggestions?
1928 Model A Hot Rod
1936 Chevy 5 window Coupes
1955 Studebaker Pick up
1961 Corvette
1968 Camaro RS/SS 4 spd with air
1969 Camaro Z10
1974 Early Bronco
svtrich
« Reply #3 on: March 11, 2010, 06:24:18 AM »
I talked to Jim at Heartbeatcity.he said he has original type ball joints that will use rivets.MADE IN TURKEY??????????? I think I will pass.if my well falls over because of the ball joint.that wont be cool :'(   I might just use ac delco stuff and see how it goes.
another kurt s
« Reply #4 on: March 11, 2010, 02:36:00 PM »
Thanks, I see many companies that sell complete rebuild kits for front ends.  My guess is that any of them could be riveted instead of bolted, I could be wrong though.  I would like to buy a full rebuild kit that has the proper look of original.  Anyone use a kit that looked correct regardless of rivets?  Can you buy the rivets seperately?
1961 Corvette
1969 Camaro Z10
1974 Early Bronco
« Reply #5 on: March 11, 2010, 03:17:37 PM »
You might want to talk to Brian at Bair's in Linesville, PA, (814) 683-4223; they have been riveting '63-'82 Corvette upper and lower ball joints for decades, and may have a line on where to get ball joints with the rivet-sized holes in them.
svtrich
« Reply #6 on: March 14, 2010, 04:59:41 AM »
I called Bairs,the ball joints that they use are made by Dana.he couldnt help for Camaro ball joints. :(
                     Richard
another kurt s
« Reply #7 on: March 14, 2010, 04:30:44 PM »
Has anybody had any luck with the complete kits like classic industries, Kanter, etc?  Any suggestions as to which looks most like original?  I realize they are bolt on ball joints but I want to rebuild my complete front suspension and subframe and none of my research has yielded a preferred brand.
1961 Corvette
1969 Camaro Z10
1974 Early Bronco
Indy 69
« Reply #8 on: March 17, 2010, 11:19:08 PM »
TRW and Moog are 2 of the more popular suspension component companies, their products are good quality.  You may find that some of the chassis mount bushings are still available from GM. ;)
jbracefan1977
« Reply #9 on: March 19, 2010, 06:37:59 PM »
moog bushings also makes a replacement
Mark
« Reply #10 on: March 19, 2010, 08:22:36 PM »
Heres an ancient discussion on Yenkos.net about riveted ball Joints, sizes of the rivets and heads, suppliers etc.
http://www.yenko.net/ubbthreads/showflat.php?Cat=&Board=UBB10&Number=174017&Searchpage=1&Main=173929&Words=rivets&topic=&Search=true#Post174017
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
jmcbeth
  • 1st and 5th Gen Camaros
« Reply #11 on: March 20, 2010, 12:55:44 AM »
Rich,
I suggest you contact Jerry MacNiesh or Ken Lucas. They both install original style riveted ball joints that are accepted by concours judges.
John
1969 Camaro Z/28 RS
Numbers Matching
svtrich
« Reply #12 on: March 22, 2010, 04:51:56 AM »
Im not looking to install the rivets.Im looking for correct looking ball joints for a 69
