Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
Oil Level
« previous
next »
Print
Pages: [
1
Author
Topic: Oil Level (Read 7464 times)
Don.Banas
Newbie
Oil Level
on:
March 01, 2010, 09:44:48 PM »
I drained the oil, replaced the filter and added 5 quarts of oil. The oil level reads about 1+" above the full mark on the dipstick.
Can someone tell me the proper lenght of the dipstick tube and the proper lenght of the actual dipstick.
I have a NOM 302 in a '69 Z28
Tweet
Logged
CRG Member
Re: Oil Level
Reply #1 on:
March 02, 2010, 05:11:38 PM »
Here are a couple of photos of an original '69 302 dipstick. From the bottom of the metal seal cup, it's 18-7/8" to the tip, 17-5/8" to the "add" mark, and 16-3/4" to the "full" mark.
Logged
Mark
CRG Member
Re: Oil Level
Reply #2 on:
March 02, 2010, 05:21:35 PM »
Did you fill the oil filter from one of those 5 qts of oil, or run the car to fill the filter before checking the level?
Logged
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Don.Banas
Newbie
Re: Oil Level
Reply #3 on:
March 02, 2010, 05:46:50 PM »
JohnZ - thanks for the measurements - I'm leaving on vacation today but will check when I return.
Mark - yes I measured the oil after running it. I only put 5 quarts total in the engine.
Logged
basecoupe#79
Member
Re: Oil Level
Reply #4 on:
March 12, 2010, 11:55:41 AM »
Your oil filter might be smaller. If its smaller than usual then you will go over the fill mark.
Logged
Don.Banas
Newbie
Re: Oil Level
Reply #5 on:
April 12, 2010, 02:32:32 PM »
OK - I finally got around to measuring the dip stick and the one I have is longer than it should be.
Now the question is - where can I get the proper one? Is there a part number or other identifying mark(s)?
Logged
GordonOne
Member
Re: Oil Level
Reply #6 on:
April 12, 2010, 02:52:02 PM »
try using the PF35 oil filter its slightly larger than the PF25......thats called out for most small blocks.Gordonone
Logged
Print
Pages: [
1
« previous
next »
Maintenance
Oil Level
