Author Topic: z28 harmonic balancer?  (Read 10759 times)
jonboy1216
« on: February 20, 2010, 12:36:31 AM »
does a 68 MO 3817173 have the cooling fins on the back of the balancer? i have seen NOS ones both ways just dont which one is right
1968 Z28
Re: z28 harmonic balancer?
« Reply #1 on: February 20, 2010, 02:19:50 AM »
My original '68 balancer does not have the fins....Looks like the finned ones were on the earlier Corvettes.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
« Reply #2 on: February 20, 2010, 03:58:19 AM »
Mine either.
« Reply #3 on: February 20, 2010, 06:31:25 AM »
My '68 Z/28 harmonic balancer is "fin-less" too.
jonboy1216
« Reply #4 on: February 21, 2010, 05:38:10 AM »
thanks guys for the info
GaryL
  • Marilyn and me
« Reply #5 on: March 05, 2010, 03:47:11 AM »
What would the fins be cooling?
Gary
« Reply #6 on: March 05, 2010, 03:50:52 PM »
Most likely someone thought it would reduce the temperature of the hub, thereby improving the durability of the elastomer material between the hub O.D. and the inertia ring I.D.; warranty and test data probably didn't support the theory, and the fins were removed. Most optional '62-'67 Corvette engines used the 8" balancer with the fins.
Jerry@CHP
« Reply #7 on: March 06, 2010, 01:37:21 AM »
Have never seen any original 302 with finned balancer.
Jerry
MyRed67
  • SZZLN 67
« Reply #8 on: March 10, 2010, 03:34:44 AM »
What Balancer did the'67 - 302 use?  Was it the same as the 350?
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
Jerry@CHP
« Reply #9 on: March 10, 2010, 04:58:19 AM »
350 8" balancer is thinner.
Jerry
SSMUNDY
  • TRIPLE BLACK 1967 CAMARO SS/RS CONVERTIBLE
« Reply #10 on: March 14, 2010, 04:28:53 AM »
Can anyone tell me what the thickness is of the '67  8" balancer? I need to know the distance between the face of the balancer where the pulley bolts on, and the back side of the hub where it meets the crank?
Sean
