Author Topic: Air Manifold Assembly Part Number (Smog system air injector pipe)  (Read 8371 times)
stovebolt
  • 1968 L6 Sport Coupe
Hi. Can anyone tell me the GM part number for the air manifold assembly (smog system air injector pipe) used on my 1968 6 cylinder engine? Thanks.
Re: Air Manifold Assembly Part Number (Smog system air injector pipe)
« Reply #1 on: February 14, 2010, 03:39:59 PM »
The '68 AIM list part number 3918952 (pipe assembly).
stovebolt
« Reply #2 on: February 15, 2010, 03:42:13 PM »
Thank you.
stovebolt
« Reply #3 on: February 18, 2010, 04:47:13 PM »
Just to be certain of the part number, I'm including a picture of the part from the Service Manual. Sight unseen, I don't want to order the wrong part. Can anyone verify that 3918952 is indeed the correct part number? Thanks.
« Reply #4 on: February 18, 2010, 05:26:11 PM »
My '69 Chevrolet P&A shows...
68-69  Chevy, Chevelle, Camaro (6 cyl.) (exc. A.T.) . . . . . 3918952     $6.60     PIPE ASSY., w/ conn., check valve . . . . . 1
Your welcome.
« Reply #5 on: February 18, 2010, 05:45:15 PM »
And in case you need the check valve & injection tubes shown in your photo, the P&A lists these part numbers...
Check Valve . . . . . . . . . 5361992
Injection Tube . . . . . . . 3880812
« Reply #6 on: February 19, 2010, 08:44:13 PM »
I don't know where you'd order it - that part was discontinued about 30 years ago.
stovebolt
« Reply #7 on: March 05, 2010, 04:58:46 PM »
Thanks for all your help. I just received in the mail the last GM inventoried 3918952 air manifold assembly from a Chevrolet dealer in Arizona.
tom
    • Discount Internet Services
« Reply #8 on: March 05, 2010, 10:05:20 PM »
Well done !
69 X11 Z21 L14 glide
o
L22K19
« Reply #9 on: March 23, 2010, 10:39:29 AM »
Can you post a picture of the NOS item.  I'm reasonably certain that the colour is original on mine but would like to be 100%. I'm assuming that the finish between a 67 and a 68 will be the same.
stovebolt
« Reply #10 on: March 24, 2010, 01:20:28 PM »
Here you are. BTW, am I correct in assuming that the pipe was made on December 3, 1975, 75L3?
Joe
