Author Topic: Spinning the wheel on info for my 69  (Read 18117 times)
rua69z
Re: Spinning the wheel on info for my 69
« Reply #15 on: February 20, 2010, 12:45:19 PM »
Jimmy V
what is your rear axle date code?
Jim S
jdv69z
  • 69 RS Z/28 52E
« Reply #16 on: February 22, 2010, 02:59:03 PM »
Rear axle code: BU0930G
Jimmy V.
Jimmy V.
rua69z
« Reply #17 on: February 23, 2010, 01:28:36 AM »
Hmm pretty close on the axle date also, I am wondering what input KurtS has on this?
Jim S
jdv69z
  • 69 RS Z/28 52E
« Reply #18 on: February 23, 2010, 02:55:40 PM »
Both cars were built within a day or so of each other, so the numbers should be close as they are. I'll bet we could compare any of the original parts from the 2 cars and the dates would be close. Some might even be the same. What's your distributor date?
Jimmy V.
Jimmy V.
jmcbeth
  • 1st and 5th Gen Camaros
« Reply #19 on: February 23, 2010, 08:02:01 PM »
At Nationals a couple of years ago, I discovered a car that was different from my VIN by 40. Exact same model, exact same options. We are pretty sure they were build on the same day in the third week of December, 1969. Is was great fun to discover this!
John
1969 Camaro Z/28 RS
Numbers Matching
« Reply #20 on: February 23, 2010, 08:47:58 PM »
Jimmy V.
Exactly. The part / sheetmetal dates should be close or the same....
67pacer
« Reply #21 on: March 01, 2010, 12:04:03 AM »
I have a question regarding the body number on this car compared to my Van Nuys built 69. 124379L524755 built 02c and is VN264129. Seems along way off.
okay youre right.i did forget  ......124379L525389       block  pad  TO208HB  L525389     VN273188   tr711   69 B pnt  02D    and the secert Van Nuys code  Q236......................thanks.... Gordon
Bill
« Reply #22 on: March 01, 2010, 04:08:47 AM »
Pretty normal for 69. It's the number assigned when the order was accepted by the factory.
Your car took a little bit longer to get on the build schedule...
What are the colors and what engine?
67pacer
« Reply #23 on: March 01, 2010, 04:22:29 AM »
Thanks for the info. My car is:   TR 725       57 57 PNT      engine  V0212DZ       BIll
Bill
« Reply #24 on: March 03, 2010, 08:03:19 AM »
Same colors as JohnZ's 02D Z!
