Author Topic: Spinning the wheel on info for my 69  (Read 18107 times)
rua69z
« on: February 12, 2010, 12:50:52 AM »
Hello I see a few vin numbers here looking for data on there respective Camaros and thought I would check to see if anyone has any anfo in the data base for it.
It is a Norwood pre x code car 10A Vin 124379N516195 it is a Daytone Yellow Z/28 standard black interior.
thanks in advance for any input.
Re: Spinning the wheel on info for my 69
« Reply #1 on: February 12, 2010, 05:37:00 AM »
Sorry, no info on it.
rua69z
« Reply #2 on: February 12, 2010, 11:24:10 AM »
Yeah well lthat's why I stay away from Vegas.
Thanks KurtS
I am curious if anyone out there has a Camaro close to mine?
jdv69z
  • 69 RS Z/28 52E
« Reply #3 on: February 12, 2010, 01:43:11 PM »
How's Z/28 VIN #516355 build 10B? 160 apart. Yours started on Friday, mine on Monday maybe? Garnet red, RS, black std interior. White stripes and vinyl top.
Jimmy V
Jimmy V.
GordonOne
« Reply #4 on: February 12, 2010, 06:33:56 PM »
well since we are SPINNING the wheel any info   on 12437 L525389  02D,  Gordon
« Reply #5 on: February 13, 2010, 03:33:13 PM »
You're missing a digit between the "7" and the "L".
« Reply #6 on: February 14, 2010, 04:28:34 AM »
Nothing other than the info from you. :)
GordonOne
« Reply #7 on: February 16, 2010, 05:43:11 PM »
okay youre right.i did forget  ......124379L525389       block  pad  TO208HB  L525389     VN273188   tr711   69 B pnt  02D    and the secert Van Nuys code  Q236......................thanks.... Gordon
jdv69z
  • 69 RS Z/28 52E
« Reply #8 on: February 16, 2010, 09:32:41 PM »
Correct me if I'm wrong here, but if rua69z's trim tag and VIN correspond to mine as we think, 160 VIN's apart,  then my car more than likely was started on Monday of week 2 (10B), which would have been October 7th '68, and his was more than likely started Friday of week 1 (10A) October 4 '68.  Or at least within a few days of these dates?
Jimmy V.
Jimmy V.
« Reply #9 on: February 17, 2010, 06:06:40 AM »
Thanks Gordon!
rua69z
« Reply #10 on: February 18, 2010, 02:10:42 AM »
Jimmy V I am curious of this also pretty close numbers, interesting on the 10A and 10B dates have you heard anything on this?
Jim S
jdv69z
  • 69 RS Z/28 52E
« Reply #11 on: February 18, 2010, 02:24:08 PM »
Jim S.
I've heard nothing else. What is the body number on your trim plate?  Mine is NOR122144. I'll bet yours is in a range close to this as well.
Jimmy V.
Jimmy V.
« Reply #12 on: February 19, 2010, 08:13:55 AM »
Yup, your cars are at the transition between weeks. And they were working most Saturdays, btw.
You both have the same trans date. Jim S, what's your axle code?
Thanks!
jdv69z
  • 69 RS Z/28 52E
« Reply #13 on: February 19, 2010, 04:14:29 PM »
Interesting, Thanks Kurt.
Jimmy V.
Jimmy V.
rua69z
« Reply #14 on: February 20, 2010, 12:09:37 AM »
 Jimmy V Body number N122057
KurtS rear axle BU926
KurtS what is the significance of that?
Thanks Jim S
