Author Topic: Chemical Dipping  (Read 13398 times)
timmorgan
Chemical Dipping
« on: February 07, 2010, 07:40:48 PM »
In a previous post on rust removal, chemical dipping was mentioned. I was wandering if anyone knows of a place in the Charlotte. N.C. area that does this? What does it usually cost? Any help appreciated!
68Z22
Re: Chemical Dipping
« Reply #1 on: February 07, 2010, 08:20:41 PM »
If it is any help there is a company In Atlanta Ga. called ECO-CLEAN that does chemical dipping.
Mark
1968 Z22
Mark
68 Z22 Coupe
LeMans Blue
327/275
bc69
« Reply #2 on: February 09, 2010, 09:13:32 PM »
Place in Evansville IN. Redi Kleen and stripping. Very reasonable priced.
Their dipping method does not use acid.
812-424-9866
Brad
RSSS
tim69camaro
« Reply #3 on: February 10, 2010, 10:32:39 AM »
Burlington, NC is the closest business I am aware of. Here is a web link. http://www.chem-strip.com/  I have know others that used them who seemed satisfied, but I do not have any personal experiece.
Tim Bailey
timmorgan
« Reply #4 on: February 11, 2010, 12:01:05 AM »
Thanks! I"m sending for a Quote now!
painterdude
« Reply #5 on: February 13, 2010, 02:14:33 AM »
Just my .02 diping is the worst thing you can do non acid or not .I have worked on several cars that have had parts and bodies done and have had to cut thing apart and the chemicals are still in the seams even if they are washed and ecoated.I have painted cars and tried to do everything possible from pouring epoxy primer in the seams to spraying grease in the seams after paint and they always bleed .
jl8dale
« Reply #6 on: February 13, 2010, 02:52:37 AM »
I don't agree.
I had my entire car chemical dipped 3 years ago. Yes, you will have to deal with some leaching of the chemical for a while, but it will eventually dry out.  I also treated all the seams with a neutralizer which really helped. Remember, most seams are out of sight too.
My car was absolutely beautiful after dipping and I am extremely happy I did it.
1969 Z/28 Daytona Yellow/Yellow Houndstooth, Tilt, Fold Down Seat, - POP
jl8dale
« Reply #7 on: February 13, 2010, 02:55:37 AM »
Here's a few pics.
PURESS
« Reply #8 on: February 13, 2010, 01:28:19 PM »
could you put the car in a paint booth and heated up like an oven and some fans...just thinking and not knowing if that that work
Barefoot Dave
    • Barefoot Dave
« Reply #9 on: February 13, 2010, 03:22:58 PM »
That might work. When I did mine I spent a few LONG days with a handheld propane torch heating and drying out all the seams. That was 5 years ago and no leaching or ill effects have appeared. If ya have the time and aren't afraid of what will come back from the dipper it's the only way to go.
Dave Miller
Fairfax VA
69 SB Z-11
69 BB Z-10
www.barefootdave.com
Buddy
« Reply #10 on: February 15, 2010, 04:01:53 PM »
Here is Eco-Clean in Atlanta
http://www.eco-clean.com/auto.htm
timmorgan
« Reply #11 on: March 05, 2010, 02:36:43 AM »
I've got my pricing back and dipping my car soon, thanks for all the feed back! I have one more question( for now ) should the cowl tag be removed? I've heard it could be damaged.
jl8dale
« Reply #12 on: March 05, 2010, 03:14:25 AM »
Yes.
Most solutions used will attack aluminum.
Take some pictures of before and after to document the removal.
You will be amazed at what the car will look like when you get it back!
Good luck!
tim69camaro
« Reply #13 on: March 06, 2010, 12:26:17 AM »
Do you mind sharing the ball park price? Are you just dipping the main body or doors and the rest?
Tim Bailey
timmorgan
« Reply #14 on: March 06, 2010, 12:39:05 AM »
1500 for the body and extra for fenders and doors.
