Author Topic: Real tag or not?  (Read 11085 times)
lcmc
Real tag or not?
« on: February 06, 2010, 03:12:17 PM »
Looking at this car. Just want to make sure it is the real deal
Danny
1969 Z/28 X77
vtfb68
Re: Real tag or not?
« Reply #1 on: February 06, 2010, 04:26:19 PM »
Painted P T B ?  First red flag.
  VT
68 08E LA RS Y2 749 L30 M35
another kurt s
« Reply #2 on: February 06, 2010, 04:32:30 PM »
Red flag for what?  The previous owner had bad taste?
1928 Model A Hot Rod
1936 Chevy 5 window Coupes
1955 Studebaker Pick up
1961 Corvette
1968 Camaro RS/SS 4 spd with air
1969 Camaro Z10
1974 Early Bronco
« Reply #3 on: February 06, 2010, 04:53:20 PM »
Amateur resto at best. From the small picture:
-Body tag has almost certainly been off the car. It should be painted; may be repro.
-Painted-over bushing and mounting screw on wiper motor.
-Missing hood to cowl seal.
-Taped paint line across top of cowl.
Proceed cautiously.
BlackoutSteve
« Reply #4 on: February 07, 2010, 01:24:43 AM »
Because they were rubber stamped, and not poorly hand painted..
lcmc
« Reply #5 on: February 07, 2010, 01:50:24 AM »
Not worried about that just the trim tag. I know there are restoration issues which I can address. I just want to make sure the car is legit.
Danny
1969 Z/28 X77
jl8dale
« Reply #6 on: February 07, 2010, 02:50:22 AM »
The pic of the tag could be better.
 IMO.....it is real.
Could be your Yellow/Yellow you have been looking for Danny!
1969 Z/28 Daytona Yellow/Yellow Houndstooth, Tilt, Fold Down Seat, - POP
Dave69x33
« Reply #7 on: February 07, 2010, 02:56:11 AM »
lcmc,
There is a long list of things to check to help validate if the car as an original X33 Z28, but the list is still not an absolute way to verify the car's origin.  Having the original paperwork, original sales documentation, P.O.P, etc. is a big help. If the car still happens to have it original “DW” code tire pressure sticker #3961733 would be a positive sign.  Obviously, if this is a numbers matching Z28, carefully document the VIN no. and date codes of the engine, transmission and rear axle date code.
If you have a copy of the 1969 Assembly Manual, study the RS option and where the vacuum hoses route thru the firewall, assuming the car has the RS option.  Also, study in the manual where the Muncie 4-Speed speedometer cable enters the firewall vs. where the automatic trans speedo cable was routing, along with the cable retaining clips on the floor pan.  These are two quick clues to check out that may help, but these two items can still be made to look original to the car, or carried over from a donor car.
There are many other clues to look for: a single 3/8” fuel line, multi-leaf rear springs, the reinforcement plate welded to the outside of the driver’s side rear frame for the duel exhaust hanger, just to mention a few.
I would also recommend that you buy the book, The Definitive 1969 Camaro Z28 – SS396 Fact Book, by Jerry MacNeish.  It contains many good facts and pictures of original Z28 component that can be used as a guide.   Also, CRG is a great site to study up on what was original on 1st Gen Z28.
Good luck with your decision.
lcmc
« Reply #8 on: February 07, 2010, 03:04:25 AM »
lcmc,
It is supposedly a numbers matching car. Waiting to see pics of the pad. I was just suspicious of the tag.
Danny
1969 Z/28 X77
lcmc
« Reply #9 on: February 07, 2010, 03:06:59 AM »
 IMO.....it is real.
Could be. I got an AAR Cuda I need to sell first. Gotta go back to my bow ties.
Danny
1969 Z/28 X77
Dave69x33
« Reply #10 on: February 07, 2010, 03:24:47 AM »
I just remembered another quick clue.  If the car was originally a “D80” spoiler car, one of the two trunk lid torsion bars will be larger than the other.  This was to help with the added weight from the spoiler.  See if they appear to be original to the car.
jl8dale
« Reply #11 on: February 07, 2010, 04:01:09 AM »
Can you say where this car is located?
Any documentation?
lcmc
« Reply #12 on: February 07, 2010, 03:22:22 PM »
Any documentation?
Located in Florida. No docs.
Danny
1969 Z/28 X77
« Reply #13 on: February 07, 2010, 11:38:39 PM »
I added all these ID features to the site a while back.
http://www.camaros.org/options.shtml#id
