Author Topic: Ride Hight  (Read 5849 times)
jacmac
Ride Hight
« on: February 04, 2010, 12:32:54 AM »
Whats the proper ride height in inches. The 69 chassis service manual "4.5" shows where to take measurement from " fig.7"& spec. section"page 4" says 5.5 inch + or- 3/8. Im sure thats correct but my cars at 8.5. Im I reading all this correctly? Car is 69 Z10 396 5 leafs spring 12 bolt!
Re: Ride Hight
« Reply #1 on: February 04, 2010, 05:49:48 PM »
Yes, those specs and the measurement location are correct (it's also shown in UPC 0 in the Assembly Manual); do you have air shocks or replacement rear springs that would jack the body up 3" above spec?
tom
    • Discount Internet Services
Re: Ride Hight
« Reply #2 on: February 04, 2010, 06:05:35 PM »
or taller tires......
69 X11 Z21 L14 glide
o
jacmac
Re: Ride Hight
« Reply #3 on: February 05, 2010, 12:05:26 AM »
No shocks on the car yet,but it does have bigger tires, 35 yr. old BF Goodrich T/As G-60. The measurment is taken from the top of the axle to the frame,would tires really make a difference? Thanks for the imput guys!
jacmac
Re: Ride Hight
« Reply #4 on: February 05, 2010, 12:10:12 AM »
Springs are original but I did put the plastic spacers in between each leaf,I know they were not original to the car.
tom
Re: Ride Hight
« Reply #5 on: February 05, 2010, 03:09:16 AM »
Axle to frame, ignore the tires. I didn't check to see what you were measuring. Any point to ground, tires can change the measure.
o
Re: Ride Hight
« Reply #6 on: February 05, 2010, 05:18:10 PM »
Nope - tires will make no difference in that measurement; your issue is with the springs.
