Author Topic: Were 69 SS also made in CA plant?  (Read 14492 times)
Racerdan
« on: February 03, 2010, 07:18:48 AM »
Struggling with a 69 that has:
Van Nuys trim tag
12 bolt original rear end with 373 gears, drum brakes- with cooling vent holes in side of drum
two line fuel line- one small, one large
Big block air radiator
hole for speedo on drivers side of steering wheel shaft hole.
brake proportioning valve under drivers side frame
engine missing
Heater box missing
Trim tag does not id it as a X-22, etc.  It is blank at this spot
Black door sills
Original rear panel replaced
Questions:
1.  Did they any make SS Camaros in California in 69?
2.  Is this a L34 or L35 car, since it has two fuel lines, one small, one large?
Appreciate any help!  Thanks!
Racerdan
Re: Were 69 SS also made in CA plant?
« Reply #1 on: February 03, 2010, 07:53:12 AM »
For clarification, the speedo hole is above the accelerator pedal, for a muncie trans.  Not sure how to edit my above post.  The radiator is # 3018624, made for COPO and 396 manual cars.  End codes on tank match OO, and has the curved neck, typical of BB air cars and COPO cars.
VIN is not on list of COPO cars, and car was made Feb 4, 1969.
HELP, PLEASE!
77thor
« Reply #2 on: February 03, 2010, 12:23:08 PM »
From my limited knowledge, I can tell you that SS Camaros were made in LOS (they did not use X codes).
As far as the the 2 fuel lines, I believe that it means that it had a Q-Jet carb.
That about all that I can help you with.
The real experts will chime in.
« Reply #3 on: February 03, 2010, 01:50:25 PM »
Of course Camaro SS were built in CA.
Whatever you have it has been messed with like many 1st gens. If it is a CA car it may have a body broadcast sheet on top of the fuel tank. For now post VIN and body tag info. If the engine mount brackets are still present are there part numbers on them?
LB68SS350
« Reply #4 on: February 03, 2010, 02:51:23 PM »
Is it disc or drum? All '69 SS would have front power disc brakes from the factory.   Larry
Racerdan
« Reply #5 on: February 04, 2010, 02:29:48 AM »
The car has front disc brakes, rear drum.
Trim Tag:
ST69= 1969 Model Year
12437= Camaro, V-8 Engine, Coupe.
VN235379= Body made at Van Nuys, CA plant, sequence # 235379 (sequence number of body is not supposed to be the same as the VIN sequence number.)
TR- 711= Trim number, black standard bucket seat interior
72 72= paint code top/bottom- Hugger Orange
01D= Date code 4th week of January (matches vin and date codes on other orginal parts like rear end.
V144= Build date of body- V= 22nd day of month, car #144 for that day.
The quadrajet was only put on the L34 and L35 396 cars, I think.  The VIN ends with 520387, made about the 4th day of February, I think.
Is there any way to tell if the car came with a 325 versus a 350 hp 396?
Thanks again!
69LM1
    • http://www.69lm1.com
« Reply #6 on: February 04, 2010, 04:13:21 AM »
Thanks again!
And the L48 and LM1 cars as well...... :)
Rich
Rich Pern
2012 Mustang Boss 302
69 COPO Camaro "Tin Soldier"
70 Z28 COPO
69 Camaro 307. Orig car from High School
click
    • Our 69 RS
« Reply #7 on: February 04, 2010, 04:38:09 AM »
But the LM1 was not built that late in January. LM1's were done by the end of Dec. :) sadly
69LM1
« Reply #8 on: February 04, 2010, 11:28:10 PM »
Ah, missed the date in the second post.....
Rich
Rich Pern
70 Z28 COPO
Racerdan
« Reply #9 on: April 14, 2018, 02:16:19 AM »
UPDATE:  I have identified the car is a Z28 Camaro, not an SS.  The 3rd owner swears it was not a Z28, but the documentation previous to him proves it was.  Some of the things that threw me off besides him was the Big block radiator, which I found out was made in June, 1970;  the clips for two fuel lines- which was on big blocks and the Z28.  Erroneously ruling out the Z28, the only other model would have been an SS.
So, the original owners family has provided me with a wealth of information saying it was a Z28, that the original owner ordered.  A newspaper article dated in June of 1971 in Eagle Grove, Iowa tells the original owners name, and that it was a Z28 as well.
The second owner was a car dealer in Iowa, who I am guessing did not know that the 69 Z28 Camaros made in California did not have X codes on the trim tag, and therefor was sure it was not a Z28.  BUT- the rear end numbers and leaf springs are so very close to the manufacturing date  it would be all but impossible to find one to match the manufacturing date of this specific Camaro.
I talked with the second owner's mechanic and body man who converted this Z28 into an SCCA race car, and he explained the damage to the car was sheet metal, and the complete driveline survived the crash and was used to race with.  This included the rear end, which had less than 23,000 miles on it.  The rear end was rebuilt in the late 1970's and 4.11 gears installed in it along with new clutches.  The Camaro only raced a couple events after that and those non original parts are still in it.
« Reply #10 on: April 14, 2018, 06:55:44 AM »
If the complete drive line survived the crash it could still be out there somewhere...
buenymayor
« Reply #11 on: April 14, 2018, 11:39:49 AM »
You sure about it being a Z/28? A Z/28 would NOT have had dual fuel lines.
« Reply #12 on: April 14, 2018, 09:31:06 PM »
Two fuel lines is an SS in that build timeframe.
Noone know to even look at the trim tags back then......
Racerdan
« Reply #13 on: April 15, 2018, 12:13:14 AM »
I found the clip that holds two lines in the Camaro assembly manual.   Page 125, UPC8  B3.
The part is numbered 4.  It is Gm part number 3886522, called a clip.
It shows in the drawing only one fuel line, but the clip clearly has two humps for two lines.  CAll me stupid, but it sure LOOKS like a two line clip, but I guess it only held one!
Remember, I am a novice!  I am here asking and learning!
Racerdan
« Reply #14 on: April 15, 2018, 12:24:22 AM »
Today, I dug out my Camaro assembly manual and found the clip.  it was used on single lines, too.  Page 125, part labeled "4", their part # 3886522.  But I was again confused for a few minutes when I read your post!  Thank you for pointing that out to me!
