Author Topic: X-22: How to determine if car was an L78 , L35 or L34?  (Read 7087 times)
MDSS396
« on: February 02, 2010, 08:24:26 PM »
1969 X-22 SS396 - It does not have the original motor/drive train in it. Are there any clues I can look for to determine what type of 396 it came with?
I am it the process of getting a records request from OH DMV - hopefully i can track down the original owners and see if they have any original documentation etc.
It does have the following:
- X-22 on cowl tag - build date matches the VIN code sequence
- Big Block heater
- Proportioning valve on sub frame
- Original fuel take with single fuel line sending unit
Thanks!
Re: X-22: How to determine if car was an L78 , L35 or L34?
« Reply #1 on: February 02, 2010, 09:14:22 PM »
Single fuel line is L78. Quadrajets had 2; one smaller return line.
Mark
« Reply #2 on: February 06, 2010, 12:02:59 AM »
All 69 camaros had a single fuel line except the quadrajet ones (L34, L35, L48 and LM1).  Big block heater cover is a bolt on item.   Make sure the tag is original.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
MDSS396
« Reply #3 on: February 06, 2010, 07:08:49 AM »
How can you determine if the tag is original or not? The date code on the tag matches the VIN.
« Reply #4 on: February 06, 2010, 07:32:24 AM »
Post a good photo of the tag here and the experts will chime in...    :)
