Author Topic: 69 - Z10 horns  (Read 5826 times)
Chill Air
69 - Z10 horns
« on: February 02, 2010, 03:42:30 PM »
Can anyone tell me what the correct numers should be?  It has 325 and 326 on it.  It look original including the welded brackets.
tom
    • Discount Internet Services
Re: 69 - Z10 horns
« Reply #1 on: February 02, 2010, 05:03:15 PM »
My interchange book says all Chevy used the same horns - high note from 65 to 75 was 1892164, low note from 65 to 71 was 1892162. That only applys to the actual horns. The mounting brackets were different for almosty every year and model. Hope that helps.
69 X11 Z21 L14 glide
o
Re: 69 - Z10 horns
« Reply #2 on: February 03, 2010, 08:05:48 PM »
The Assembly Manual calls out 9000290 (LH) and 9000289 (RH) horns.
Chill Air
Re: 69 - Z10 horns
« Reply #3 on: February 03, 2010, 11:52:46 PM »
Thanks for the help.........Found out today these horns fit a '57 chev.  what a surprise!!!!!!!!!!!!
tom
Re: 69 - Z10 horns
« Reply #4 on: February 04, 2010, 01:48:45 AM »
FWIW I think the difference between the numbers I posted, and the numbers John posted is the attached mounting hardware.
o
Jrschev
Re: 69 - Z10 horns
« Reply #5 on: February 04, 2010, 12:53:17 PM »
The horns for a 69 Camaro look nothing like that at all. Those are the old style horns with an entirely different bell and the housings are also very different. For the most part, 1969 horns were pretty much all the same across the GM line. The difference was in the brackets. Of course there are different notes so that when you had dual horns you had one low note and one high note so that they harmonized. There are also more than two notes: E F G H etc.....   It can get tricky finding the right ones for 69 Camaros if  you are not sure about what you are looking for.
Side note:  All service replacement horns were the same for all the cars. They came boxed with a bracket that was installed separately so that they could mount to any application. The horn was black and the bracket was just plain plated. The bracket was afixed by a big nut that secured it to the horn. You could not order the exact horns for your car through the Parts department even when your car was new. GM did this to simplify the replacement of horns and as far as they were concerned they did the job as a replacement. That's why you sometimes see these horns in Delco boxes as NOS for sale without a bracket on them. That's also why it is so difficult to come up with a part number. I believe the number John Z gave is the one that will be cast on to the horns you need as they fit only 69 Camaros and all 69 Camaros used the same horn(s).
1969 Z11 Pace Car (05A) 350/300 L48 4-Speed
Re: 69 - Z10 horns
« Reply #6 on: February 04, 2010, 06:00:03 PM »
That's correct - the two numbers I mentioned are on the end of the horn bells, along with the date code; the production-line horns were received as an assembly (horn and welded-on mounting bracket); the horn with a separate bolt-on mounting bracket was a Service-only phenomenon.
