Author Topic: DZ Block Vin  (Read 8016 times)
KRB5000
DZ Block Vin
« on: January 25, 2010, 12:35:26 AM »
I have a 69 DZ block and the area where the vin should be ( at the oil filter ) is very rough. Can't see any numbers. I was wondering what would be the best way to make the numbers readable without taking a chance on destroying them. Thanks
sixt9x33rs
Re: DZ Block Vin
« Reply #1 on: January 25, 2010, 12:53:02 AM »
Is the motor in the car?
KRB5000
Re: DZ Block Vin
« Reply #2 on: January 25, 2010, 12:58:39 AM »
No, unfortunally I don't have the car. I have tried crayon and marker with no luck.
vdavie
Re: DZ Block Vin
« Reply #3 on: January 26, 2010, 04:53:16 PM »
Try this:  http://www.crime-scene.com/store/A-8108B.shtml
I used it before and it did work.
Vince
tom
    • Discount Internet Services
Re: DZ Block Vin
« Reply #4 on: January 26, 2010, 05:55:49 PM »
Before resorting to chemicals, I would try different lighting effects (straight on multiple angles, and intensities. I would also try several crayons, and rubbings (paper over area, rub with a pencil) Vin stampings could also be near the engine code stamping: http://www.camaros.org/drivetrain.shtml#partialVINs
 did you check there?
69 X11 Z21 L14 glide
o
vdavie
Re: DZ Block Vin
« Reply #5 on: January 26, 2010, 06:00:45 PM »
The acid does not hurt the block or the stamping..when i did it anyway. Just clean the area, sand it if you need to then put it on with a cotton swab. You can  sit there and watch it do its thing. When you see the numbers you just put on the Neutralizer and put a bit of oil on it so it dose not rust. Its made for this purpose
Vince
KRB5000
Re: DZ Block Vin
« Reply #6 on: February 02, 2010, 11:33:12 PM »
Thanks guys, I think I will try the acid. There are no numbers by the engine code. Have tried lights and crayons with no luck. Again, thanks for all the help. This is a great site!!!!
Indy 69
Re: DZ Block Vin
« Reply #7 on: February 02, 2010, 11:52:02 PM »
Nothing wrong with using a good old fashioned wire brush!
I have just been through the same and it worked fine.  ;)
sixt9x33rs
Re: DZ Block Vin
« Reply #8 on: February 05, 2010, 12:49:05 AM »
Dont use sand paper or a wire brush on the engine pad. You will ruin the broach marks if there are any.
Indy 69
Re: DZ Block Vin
« Reply #9 on: February 05, 2010, 01:41:18 AM »
Good call, of course proceed with caution, but my numbers were in the rough casting of the block and there is no way would sandpaper or a wire brush remove anything that is was not meant to, ie: paint and grime etc.  8)
