Author Topic: 1967 Camaro radius rod research  (Read 84657 times)
« on: January 23, 2010, 03:04:17 PM »
I just updated the radius rod article, http://www.camaros.org/radiusrod.shtml, with new pics (thanks Ron!) and new information. But we really don't have a lot of clarity in the data, especially for the first cars that used radius rods.
We are looking for more information from any SS, Z, or L30/M20 that was made Dec 66 or later. Especially SS350 cars made in December or January and L30/M20 cars made in December thru March.
You can email the information below to either me or Daniel (CamaroDan@juno.com) or to post it on this thread.
The information that we're looking for is:
1) Build date
2) Model (SS350, L35, L78, Z28, or L30/M20)
3) Does your car have a radius rod? If so, round or rectangular?
4) If not, does it have either the body bracket or the axle bracket?
5) VIN (Feel free to email if you don't want to post it. We need to the VIN to be able to sort and reference the data. It will not be published or released in any form.)
Helpful extra credit (esp for the early SS350 and L30/M20 cars). :)
6) Axle date (e.g. QJ0421G1). See http://www.camaros.org/drivetrain.shtml#axle for the location.
7) Do you have any documentation for the car?
Thanks for the help!!
Re: 1967 Camaro radius rod research
« Reply #1 on: January 24, 2010, 04:44:34 PM »
The report still could use a better pic of the round bar installed in a car (same angle as the rectangular bar would be great) and some pics of the axle brackets (without a rod installed).
If anyone has a dealer-added bracket/rod, that might be a good pic too. Not sure if pics would show the differences though.
Thanks!
Buddy
« Reply #2 on: January 24, 2010, 05:14:04 PM »
My car is in pieces so I will get all I can for you.
Buddy
philip
  • hello from FRANCE
« Reply #3 on: January 24, 2010, 09:17:19 PM »
i have send you the caracteristic of my 67 convertible L30M20.( 129824)
chevrolet camaro F32712667         ST 67 12667 nor 30510
                  TR 765Z      c-2
                  XDL 2LG 3L
                  5BO
124677N129824
moteur T1102MK: t tonawada 11 novembre 02 le 02 novembre MK 327 275HP de 67
boite de vitesse R7R06: R = 4-speed Saginaw model du 06 octobre 66
pont : PE1004G( ou C ou 6?)
     E
rapport 3.08 10 bolts positraction
CARBURATEUR ROCHESTER QUADRAJET 7027203 DZ 97
            DP29865
i can say that i have a 10bolts rear axle with positraction 3.0_ ratio and i have no rod neither support on the axle or the body
convertible 1967.12467
RPO: A02-A31-A67-B37-B93-C06-D55-F41-G80-J50-J52-K02-L30 -M20-N33-N40-N61-U17-U18-U25-26-27-28-29-V31-V32 Z21-Z22-Z87
« Reply #4 on: January 25, 2010, 02:50:53 AM »
Buddy,
Do you still have the maroon BB?
Philip,
They didn't install a rod on 10 bolt axles and the L30/M20 didn't get a 12 bolt until a couple of months after your car. Thanks!
westonz28
« Reply #5 on: January 25, 2010, 04:30:14 AM »
Kurt I think you have all the information on my L30/M20 vin#124377L150010. If not let me know and I will get you all I have. Wes
67 RS L30/M20 numbers, 68 BB 396 12 bolt posi
68 Z28 project, 68 numbers 327/210 4 speed
69 LM1 turbo 350 12 bolt numbers,70 L65 350
68 Chevelle L30 3 on the tree, 68 El Camino BB
« Reply #6 on: January 31, 2010, 05:01:40 AM »
Wes,
Yup, both brackets were there, but no rod.
David,
Thanks for the axle bracket pics!
Buddy
« Reply #7 on: January 31, 2010, 04:27:46 PM »
Yes, I still have the Maroon Big Block, Do you already have my info??
Thx
« Reply #8 on: January 31, 2010, 10:27:47 PM »
Buddy,
You sent in the info 10 years ago, but we don't have any axle or rod info. I'll send you an email.
1967RS/SS
« Reply #9 on: April 03, 2010, 03:33:46 PM »
I am trying to verify if this is the original differential.  I snapped some quick pictures and tried to get some numbers
Build Date: 01C
SS350
No radius rod since I have had it
I will PM you my VIN
I have the POP only.  Havent found a build sheet (have not looked too hard yet).
QL01116 (Q looks like an O)
« Last Edit: April 03, 2010, 04:03:12 PM by 1967RS/SS »
1967 RS/SS L-48
Van Nuys 01C
Joseph
LVN 67
  • John 67 NOR 02E L-35/T400, 6th Owner
« Reply #10 on: June 08, 2011, 11:30:51 PM »
I have the following info from my 67 L-35 Coupe
Build Date: 2-E
Round Radius Bar
7N185414
Rear: QU0221G
I have POP and some of the previous owners service records
rs1967ss
« Reply #11 on: July 18, 2011, 05:46:14 PM »
Build date- 2B 3L/4P L142305 has the bracket, no rod, no axle bracket. But my mystery is a 10 bolt rear! Could this original? The date lines up perfectly for the car
Kelvin Scott 67 SS/RS350 Marina/Black/dlx Parchment VanNuys 02B
jcfcamaro
« Reply #12 on: October 10, 2011, 01:15:15 AM »
Here are some pics of the floor of my 01c  4p car!!!  The motor,4spd, 12bolt,have been changed out so there is no longer a rod,but the plate and bolts are still there!!
jcfcamaro
« Reply #13 on: October 10, 2011, 01:16:16 AM »
inside the car
jcfcamaro
« Reply #14 on: October 10, 2011, 01:30:45 AM »
It's a 67
