Author Topic: 1967 Camaro radius rod research  (Read 84452 times)
Re: 1967 Camaro radius rod research
« Reply #30 on: May 23, 2014, 07:10:08 PM »
You're welcome, Mike.  I looked at the axles again and they match up with your observations.
MO
« Reply #31 on: May 24, 2014, 05:31:28 PM »
0320 PU Square Hole
« Reply #32 on: May 24, 2014, 05:39:10 PM »
Date   Code     Radius Rod        Rear Hole
                    Round/Square         Y/N
___________________________________
0126   QL         Square                 N
0303   PJ          Square                 Y
0320   PU         Square                 Y
0331   QK         Square                 N
0404   BJ          Round                  Y
Mark
« Reply #34 on: May 27, 2014, 06:35:58 PM »
Yes they did, and they used two of them on an axle.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
luv2sixty9
« Reply #36 on: May 29, 2014, 02:02:58 PM »
I have seen Birds with the square bar also.
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
little_hoss
« Reply #37 on: July 24, 2014, 01:24:04 AM »
Does anyone know if the front bracket and the plate welded to the body are the same on a firebird as on a camaro? Looking at the one eBay the bracket does look similar.
Eric
1967 Base
1969 Base 307 3spd matching #'s X44
1968 C-10 Short Fleetside Custom
« Reply #38 on: July 24, 2014, 01:30:15 AM »
Yes, those pieces are the same.
little_hoss
« Reply #39 on: July 25, 2014, 11:36:06 PM »
Didn't know that! Thanks! I found a firebird in the junkyard last year that still had the radius rod assembly on it. Going to go this weekend to see if it's still there.
Eric
1967 Base
« Reply #40 on: July 25, 2014, 11:41:19 PM »
 I thought those plates are now in reproduction.
little_hoss
« Reply #41 on: July 25, 2014, 11:47:57 PM »
I don't know. I've seen the brackets and radius rods though so I would imagine they are. Anyone know who has them? I am also going to look for parts for my '68 C-10. Just going to have a fun Saturday  ;D
Eric
1967 Base
little_hoss
« Reply #42 on: July 26, 2014, 12:03:54 AM »
Yep, you're correct. Just saw all the brackets and plate for sale on the Rick's Camaro website.
Eric
1967 Base
bc69
« Reply #43 on: May 02, 2016, 09:50:01 PM »
12C RSSS L48 with only old style bracket on QK1215G Diff
Brad
RSSS
Vince
« Reply #44 on: September 15, 2016, 06:46:25 PM »
Kurt,  I recently acquired a 1967 SS 350 (RS package also) with a Powerglide trans.
01D build date
no radius rod
2nd design axle bracket; no body bracket, just the 2 bolts coming thru the floor
VIN is 124377N178723
rear axle is QK 0120 G
unfortunately I have no documentation for it
