Author Topic: Choke Cover Paint  (Read 3838 times)
68rs327conv
    • The build
Choke Cover Paint
« on: January 21, 2010, 12:23:15 PM »
On a base engine with painted intake, was the choke cover painted or unfinished?  Also I assume the thermostat housing bolts were also painted as this was installed before the engine was sprayed, correct?
68 RS Conv 327/210hp, Powerglide Factory AC
Re: Choke Cover Paint
« Reply #1 on: January 21, 2010, 02:54:24 PM »
The remote choke coil and cover was installed at the car assembly plant, and was not painted; the thermostat housing was on the engine when it was painted.
SSMUNDY
  • TRIPLE BLACK 1967 CAMARO SS/RS CONVERTIBLE
« Reply #2 on: January 21, 2010, 03:17:40 PM »
What head markings should be on the thermostat housing bolts? Is it the same for a '67?
Sean
