Author Topic: 69 302 dz flywheel & starter  (Read 6268 times)
anastasios
« on: January 21, 2010, 01:56:25 AM »
i have a number matching 1969 z28. the clutch just went on it and while changing it i noticed it has a 10.5 clutch small flywheel and the starter nose is not steel. A friend was also puzzled , we thought it would have a 11 inch clutch, big flywheel and a steel nose starter. what did they come with any help would be appreciated .  Thanks Tom
ss jim
Re: 69 302 dz flywheel & starter
« Reply #1 on: January 21, 2010, 02:05:42 AM »
10.5 would be correct. Jim
Jerry@CHP
« Reply #2 on: January 21, 2010, 02:14:38 AM »
starter should be an 8367 with aluminum nose.
Jerry
anastasios
« Reply #3 on: January 22, 2010, 01:42:16 AM »
thanks guys
ibfootin
« Reply #4 on: January 23, 2010, 08:56:28 PM »
My flywheel is drilled and tapped for the 10.4 inch as well as the 11 inch.  It actually had the 10.4 disc and the 11 inch pressure plate.  I went back witn both 10.4"
