I have a 69 camaro that i am pretty sure was originally a small block car, now it has a b.b. My problem is that after installing the engine it appears to me that it sets to far forward, there is plenty of room in between the block and firewall to acess the bell houseing bolts, most that i have seen are very tight. The the clutch adjustment rod is to short, the bell crank is angled foward, and when installing the crank pulley it has very little clearence, if any at the frame.
I realize that the b.b. requires special mounts that attach to the frame for the motor mounts, the ones i have, have these numbers stamped in them, the left side which is taller is 3950113, the right side is 3950114, both after market as well as the bell crank and clutch adjustment ass.
The 4-speed trans lined up with the trans mount with out any problem, the drive shaft measures 50" center to center. Does any one have ANY advice???
Is there a number stamped in the sub frame, and if so where?
