Author Topic: engine / frame mount mods ?  (Read 3153 times)
aussie68cam
  • Dave
« on: January 18, 2010, 08:38:24 AM »
Hey guys, does any body know if you have to modify the frame or engine mount if you install a 2' cowl hood. at the moment my 350 (i have a 68 camaro sedan) sits very close to the firewall and the extractors hit the steering box and pitman arm anyhow if i move the motor so the air cleaner sits dead in the middle of the induction hole my frame mounts and the engine mounts dont line up. i have exact no matching frame mounts and the correct engine mounts. has any body had this problem, other forums have said they have had problems with extractors hitting steering components and having to put washers and plates to solve this problem.any help would be much appreciated. dave
