Author Topic: 1968 Monoleaf Rear Spring Front Bushing  (Read 7282 times)
stovebolt
  • 1968 L6 Sport Coupe
« on: January 11, 2010, 04:09:58 PM »
Two questions: when the monoleaf rear springs were available from GM, did they come with the front bushing installed or was the bushing sold seperately? Also, has anyone installed the Perfect Circle front bushing. How is the quality, would you recommend them? Thanks, Joe.
Indy 69
Re: 1968 Monoleaf Rear Spring Front Bushing
« Reply #1 on: January 11, 2010, 06:47:20 PM »
Joe,
The Perfect Circle bushings are fine from my experience with them. Also, they are available from Moog and TRW if you need others to look at.
I do not know about the springs being supplied with the bushing already installed, I am sure someone here will have the answer for you..   ;)
stovebolt
« Reply #2 on: January 12, 2010, 03:16:43 PM »
Does anyone know the TRW or Moog part number for this bushing? Thanks.
« Reply #3 on: January 12, 2010, 03:19:25 PM »
The monoleaf springs came with the front bushing already installed by the spring supplier; the rear shackle bushings were separate, installed at the car assembly plant.
Indy 69
« Reply #4 on: January 12, 2010, 08:27:22 PM »
From memory the 2 companies have the same part# B298.
stovebolt
« Reply #5 on: January 13, 2010, 01:56:05 PM »
Thanks to all for your help. Joe.
