Author Topic: Convertible question  (Read 3490 times)
outlaw17
« on: December 27, 2009, 03:54:20 PM »
I am doing the body and paint on a 67 convertible for a guy I know and I came across a spot that I am unfamilliar with. The panel that is between the trunk lid and the top , on a hard top it is left to look like a seperate piece, but on this car it had the lines like it was a seperate piece but when I stripped it down it was done with filler and what was under it was a lead joint, what I need to know is if this is a smoothed area on a convert. or if it should have the joint lines.
Re: Convertible question
« Reply #1 on: December 27, 2009, 04:10:32 PM »
They're smoothed, hence the lead. They either put the lines in not aware of what's correct or cracking was evident and used a faux seam as an expansion joint.
outlaw17
« Reply #2 on: December 27, 2009, 09:59:48 PM »
Thank you Sauron327 , thats what I assumed but was not completely sure.
