Author Topic: 68 Z28 Cowl Plenum air cleaner components availability?  (Read 19859 times)
Prackman
« on: December 26, 2009, 05:48:24 PM »
Any known source for reproduction cowl plenum air cleaner components for a 68 Camaro?
Was this dealer installed add-on really that functional and worth installing if one was found?
John
1969 Z/28 VN Built
1967 SS
LB68SS350
Re: 68 Z28 Cowl Plenum air cleaner components availability?
« Reply #1 on: December 26, 2009, 09:49:47 PM »
There sure is. Try these guys-  www.taperfresto.com  Good Luck!   Larry
john302
« Reply #2 on: December 27, 2009, 02:51:43 AM »
You can also try Nelson Rudilson. He sells all steel repops.The ones that TA PERFORMANCE sells are made out of fiberglass. Not very correct .If you want a real one I would sell one of mine. Thanks John  Allouez Restorations
LB68SS350
« Reply #3 on: December 27, 2009, 04:14:02 AM »
I guess it depends how much somebody's willing to pay for one, or for an original when you get down to it.The ones that TA perf resto sells are $950. Shop around!
Charley
« Reply #4 on: December 27, 2009, 07:01:11 AM »
There were some nice repo ones on Ebay...
fireZ
« Reply #6 on: December 27, 2009, 02:51:03 PM »
I tried to get a hold of the fellow Charley said but had no luck. Does anyone know if his are steel or fibreglass?
1968 Z28 LA Built
LIC # RPO Z28
Charley
« Reply #7 on: December 27, 2009, 03:26:48 PM »
"This is a very close reproduction assembly in steel and
    aluminum of the original cowl plenum and the duct. This part is very durable and will not disappoint in fit and
    finish. I have the mold and can reproduce more plenums and ducts on request, The inside of the duct also
    has a smooth finish making this reproduction part very difficult to tell apart from the originals with the
    exception that this part is better looking and surpasses other similar aftermarket parts that sell for more."
Jerry@CHP
« Reply #8 on: December 27, 2009, 05:02:31 PM »
Nelson's are about the best.  And they are nice.  The fiberglas ones are not good and do not look anything like an original.
Jerry
Prackman
« Reply #9 on: December 27, 2009, 05:14:48 PM »
Jerry
Jerry - does "Nelson" have a website?
John
1969 Z/28 VN Built
1967 SS
LB68SS350
« Reply #10 on: December 28, 2009, 04:43:59 AM »
Here you go-  NKR Products  Nelson Rudisill  828 874 2335  North Carolina
Prackman
« Reply #11 on: December 29, 2009, 04:01:10 PM »
Thanks everyone for your replies about the availability of this style of air cleaner, but WOW what a cost!
Going to my original 2nd question, did this style of AC provide that more of a performance factor?
John
1969 Z/28 VN Built
1967 SS
lakeholme
  • 68-12D L30/M35
« Reply #12 on: December 29, 2009, 10:14:27 PM »
That's in Rutherford College, NC...
Website info: http://webpages.charter.net/nelsonrudisill/nkrproducts/contacts.htm
« Reply #13 on: December 30, 2009, 02:32:23 PM »
The (minor) benefit was colder intake air; the rule of thumb is that you'll get a 1% power increase for every 10*F reduction in intake charge temperature. The other (perceived) benefit is intake roar when the flapper valve opens at WOT. :-)
« Reply #14 on: December 30, 2009, 06:13:55 PM »
Somewhere in Smokey Yunicks' book he mentions developing the plenum air intake with Chevy for the '63 Mystery Motor cars he ran at Daytona. He stated at speed it also provides a few pounds of boost.
