Author Topic: Dealer optioned 67 Camaro  (Read 19792 times)
Indy 69
Re: Dealer optioned 67 Camaro
« Reply #15 on: January 02, 2010, 08:12:08 AM »
 Dare I asK??
We all know what the car is now and I imagine that a lot of the members on this site are asking what is actually behind the initial posts of this car?
Are you buying the car, is it for sale and/or have you been trying to determine the vehicle's originality before purchasing etc?
We would assume that it is a matching numbers deal?
Nicely optioned car and one of many good cars to be imported into Australia in the the 60's.
Good luck with it!
monaroman
« Reply #16 on: January 02, 2010, 12:11:48 PM »
Hi there,
What should be the Transmission code on this vehicle's trim tag.
Cheers.
RS3SDL2MG
  • Brad
« Reply #17 on: January 02, 2010, 01:09:55 PM »
Hi there,
Cheers.
trim tag has no transmission letter in section 2 ? if it was a powerglide it would be M or muncie 4 speed it would be L
I don't think I've ever seen one with no transmission listed ?
1967 RS 327 (210) horse C-C ermine white 732 bright blue interior RARE 4P - DELETE
Mark
« Reply #18 on: January 02, 2010, 02:08:02 PM »
Its a HD 3 speed manual transmission, the default transmission, if you didn't select a 4 speed, or an auto transmission both of which were options.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
ccargo
« Reply #19 on: January 02, 2010, 05:22:45 PM »
No designation was used for the TH400 auto transmission at the time this car was built. At NOR they eventually started using a "Z" for TH400 and at LOS they eventually went with "M" for both powerglide and TH400. Correct me if I'm wrong here but this car was fitted with a TH400 automatic.
67 O-1 O4A L35 Convertible, Indy Zone IPC
monaroman
« Reply #20 on: January 02, 2010, 08:50:11 PM »
Hi Guy's,
Interesting.
02B- TH400 was a option???
Cheers.
« Reply #21 on: January 02, 2010, 11:02:48 PM »
Yup, the TH400 became available when the 396 was introduced.
monaroman
« Reply #22 on: January 04, 2010, 08:13:40 AM »
Hi Guy's
I have been reading up on some of the options on this Camaro.
I beleive the L35 was a option in LATE 67 not EARLY 67
Can any give a specific month in late 67 the L35 was made available please.
Cheers.
Mark
« Reply #23 on: January 04, 2010, 04:11:53 PM »
January of 67.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
monaroman
« Reply #24 on: January 11, 2010, 09:53:31 AM »
Hi there,
If not sure if any over analyising here but does the number 3 (bottom part) look a little small?
stovebolt
  • 1968 L6 Sport Coupe
« Reply #25 on: January 20, 2010, 01:26:15 PM »
I have a question about the Camaro Order Form further up this thread. In the transmission section it lists the Powerglide, 4 speed wide ratio and 3 speed transmissions. It doesn't mention the close ratio 4 speed transmission. Just curious. Joe.
monaroman
« Reply #26 on: January 27, 2010, 05:28:36 AM »
Hi there,
Can the following please be explained. I have done some researched i just want to be sure
Cheers
Production Tracking Number-
Sequential Body build number-
« Reply #27 on: January 27, 2010, 03:25:00 PM »
Sounds like you're researching via a book. Those are 'made-up' terms that GM did not use.
See http://www.camaros.org/numbers.shtml#CowlTag.
monaroman
« Reply #28 on: January 27, 2010, 11:03:59 PM »
Hi Kurt,
Cheers for your response.
Correct i have 3 to 4 Camaro references, hence sometimes with some information it can get a little confusing.
