Author Topic: 67 headlight switch w /U17 console instruments  (Read 24736 times)
My68SS
Re: 67 headlight switch w /U17 console instruments
« Reply #15 on: September 30, 2010, 05:51:42 PM »
It may be that the max resistance of the dimmer fitted is different depending on options and therefore the number of lamps [total current] it has to control, so the same dimming range is acheived.
Might be interesting for those with dimmers lying around and a good, accurate low ohms reading dmm to measure their dimmers along with what number it has stamped on it.
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
flyingskibiker
« Reply #16 on: September 30, 2010, 11:14:08 PM »
My ~11C '68 has 164 on the side.  Here to help... ;-)
big iron
« Reply #17 on: October 01, 2010, 12:13:41 AM »
Rob,
 I believe there is a physical difference in the size of the ceramic material that the dimmer w/gauges has that also allows for a higher wattage capacity in the dim position.
I have seen replacements that the dimmer section is 2x the size of the 147 that I have.
The 67 console w/gauges and 4 spd. have 5 additional lights and w/auto trans. 7. For the dimmer to dim the additional lights you would have to increase the dimmer resistance to drop more of the voltage at the dimmer.
There are 4 dash,2 court. and 1 dome ( 2 deluxe) = 8 lamps so you would need probably 2X the resistance of the 147 sw.
My original 147 shows 0 to 7 ohms across the resistor, measured with a Fluke 83. I used the # 3 trem. and the wiper for my measurement. I also tried term #2 and term#3 and could only get 0 to 6.3 ohms.
Bob
big iron
« Reply #18 on: October 01, 2010, 12:18:49 AM »
Does your build have a console w/ gauges?
Is it stamped on the plastic or the metal bottom?
Bob
flyingskibiker
« Reply #19 on: October 01, 2010, 06:52:46 AM »
No idea if car came w/ gauges from the factory...  The car does have the tic-toc-tach and most wires match up w/ that (clock power w/ correct connector).  But the harness is pretty well hacked and unwrapped.  I haven't checked to see if the wires going to the aftermarket gauges are the correct color and go into the bundle of wires under there (gauges are mounted under the center of the dash where the U17s would be).  I will be doing that in the next couple months since I plan on replacing the harness and installing a console w/ gauges.  There IS the correct oil line hole in the firewall.  I did check that.  There is also a hole for the Muncie speed-o cable and jumper harness and hole for the back up lights.
If I look in the instrument cluster opening w/ them out of the car like they are now, I can look at the side of the switch and see it stamped into the metal near the rear of the switch.  It is not on the bottom as the switch is currently mounted.  The switch know release button is on the same side facing the cluster opening, as well.  I could take a picture pretty easily...
I bought an aftermarket switch.  I could easily measure the resistance on it.
My68SS
« Reply #20 on: October 01, 2010, 09:32:02 AM »
Bob
Hi Bob,
It will be the other way round - more lamps = lower dimmer resistance.
e.g. For a given dimmer position/resistance, as you clip more lamps in parallel, the brightness of any one lamp decreases, as more voltage is dropped across the dimmer.
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
Mark
« Reply #21 on: October 01, 2010, 04:53:32 PM »
The resistance of the dimmer is fixed, its the wattage of the resistor that increases.  As you add more bulbs in parallel the circuit resistance gets lower, but the resistance thru any one bulb remains the same.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
My68SS
« Reply #22 on: October 01, 2010, 05:24:16 PM »
That's true, more watts will be dissipated in the dimmer as you add more lamps. I was only wondering if they also changed the resistance of the dimmer to keep the same dimming range.
It may well be that this was considered of minor consequence and only the wattage of the dimmer was considered.
Having said that though, to some extent the two would go hand in hand anyway, higher wattage capability = heavier wire = lower resistance anyway [for roughly similar wire lengths]
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
big iron
« Reply #23 on: May 12, 2014, 03:27:18 AM »
Does anyone know why there are 2 67 headlight switches. Std.1995147 and 1995149 w/U17. Does the 149 have a higher rated light dimmer for the console ? See VPC 12 B6 and revision 4. ???
Anyone have an answer ?
His67PC
« Reply #24 on: May 21, 2014, 01:40:54 AM »
Attached are some pictures of 147 and 149 switches from cars I parted in the 70s.  Other than the dimmer switch blocks at the front of the switch, they look the same.  The 149 switch is the lighter colored dimmer.  There are some minor configuration differences in the dimmer block and the dimmer dial on the shaft is different.  I don't know know which pins to measure for resistance to tell the difference.  They may not be good as the dimmer was a common failure mode for these switches.
His67PC
« Reply #25 on: May 21, 2014, 01:42:34 AM »
A couple more shots:
His67PC
« Reply #26 on: May 21, 2014, 01:43:36 AM »
And...
big iron
« Reply #27 on: May 21, 2014, 04:52:02 PM »
Thanks for the reply His67PC,
Your picture of the 149 switch tells the whole story about the 67 option RPO U17.
Bob
