Author Topic: Why is there some Z28's with 3908326 Rear Proportioning Valves and Some without  (Read 38102 times)
bbd564
July 67 Build Norwood L78 has valve
July 68 Build Norwood Z28 has no valve
westonz28
Ok heres mine. 1967 RS 327 L30/M20 LOS 03D with the valve, 1968 SS/BB  NOR 10B with valve, 1968 coupe 327 210hp LOS 03A no valve, 1969 LM1/350 auto LOS 11D with valve. Only one of them is an SS Camaro. Hope this helps. Corrected with build date and plant. Why does the 1967 RS have the valve as it does not fit the 1967 data? Any ideas Kurt?
67 RS L30/M20 numbers, 68 BB 396 12 bolt posi
68 Z28 project, 68 numbers 327/210 4 speed
69 LM1 turbo 350 12 bolt numbers,70 L65 350
68 Chevelle L30 3 on the tree, 68 El Camino BB
jdv69z
  • 69 RS Z/28 52E
Oct 68 10B  build Z/28; no valve.
Jimmy V.
Norwood
Jimmy V.
Jimmy V.
