Author Topic: What Are These Here For?  (Read 5501 times)
BlackoutSteve
« on: December 22, 2009, 04:45:48 AM »
Underneath the headlamp and wiper switches of a 69 instrument carrier are two notches with corresponding holes in the dash bracket.
I had a good look though the AIM and couldn't see what they may have been used for. I thought maybe the V75 liquid tire chain switch, but that's installed into the column cover.
Any ideas?
(Please note that the picture I have included as an example has the radio plate above these holes because I am performing a left to right steering conversion and have swapped the two plates. :P)
Mark
Re: What Are These Here For?
« Reply #1 on: December 22, 2009, 05:12:22 PM »
Can't see the pictures from work (blocked) but they could be for the speed warning adjustment knob. or for the grounding connection thats behind the windsheild wiper switch.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
« Reply #2 on: December 22, 2009, 05:27:01 PM »
Going from memory (uh-oh), I think Mark got both of them.
BlackoutSteve
« Reply #3 on: December 22, 2009, 10:43:37 PM »
Thanks guys.  :)
Yes, I can see in U15-A1 that, it is the speed warning device which appears to use only one of the notches for the mounting bolt and the adjustment knob is on the device's bracket. Thank you!  ;D
However, the headlamp grounding connection UPC12-B2 is sandwiched between the instrument carrier's mounting screw and the ground wire is screwed into the dash bracket, so it doesn't use them.
Maybe the second notch and hole is a provision for an accessory that wasn't required..
Mark
« Reply #4 on: December 23, 2009, 12:46:07 AM »
You made me go out to the garage and look.  My outer one (left most) has the under dash light screwed into it.  Convertible only feature.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
BlackoutSteve
« Reply #5 on: December 23, 2009, 12:54:28 AM »
That'll be it!  ;) (..and U29 for coupes)
Thanks again.
