Author Topic: clean up and polishing Windshield and rear glass molding  (Read 28871 times)
tmodel66
« on: December 10, 2009, 04:09:59 AM »
I have good molding that is original to my '69SS.  I would like to keep it but as you probably know it is "white" dull. I have tried several polishes and wax and cream and I am just wasting my time and money. Can anyone tell me where to send it to get it polished out  like new?  I am about to do a  face lift and spruce it up a little and I just can't get it to shine like it's supposed too.
OBIWAN2T
Re: clean up and polishing Windshield and rear glass molding
« Reply #1 on: December 10, 2009, 04:41:21 AM »
Daniel,
   I just did this to my 67 camaro. Get a grinder and put a polishing wheel on it. Then get a couple of sticks of polishing compound, one cleaner & one final polish, and CAREFULLY go to work. The original stuff polishes out to a brilliant shine!
Todd
tmodel66
« Reply #2 on: December 10, 2009, 04:50:52 AM »
Thanks Todd  could you give me the name of the stuff you used?  Still better give me the part number off what you used along with the name then I can't go wrong.
KevinW
« Reply #3 on: December 10, 2009, 12:38:47 PM »
Dan, take a look at this site and read the tech docs as well as the forums  http://www.caswellplating.com/buffs/  Lots of info on polishing.  I did my stainless trim, easy, but time consuming.  It came out nice!
OBIWAN2T
« Reply #4 on: December 14, 2009, 08:22:23 PM »
Daniel,
  I got it @ Lowes ( of all places ) I just got your reply & I'll go out to my shop tonight and see the exact name of the 2 polishes I used. If that will be helpful I'll be glad to do it.
Todd
« Reply #5 on: December 15, 2009, 04:17:58 PM »
The original stainless steel reveal moldings were flash-chromed after polishing, to protect them from oxidation/dulling; to polish them, you first have to get through the clear chrome layer, and when you're done, they should be flash-chromed again, or they'll dull over time.
tmodel66
« Reply #6 on: December 17, 2009, 10:02:21 PM »
Thanks for the insight John.      Bet you don't know where a chap could get the flash chrome done?   I don't know about replacement moulding.   Do they fit ?
« Reply #7 on: December 18, 2009, 03:15:15 PM »
You'll have to check with platers in your area to see who can do flash-chrome. I haven't heard anything good about the fit of reproductiion reveal moldings - perhaps someone else can comment who has experience with them.
mrdetails
« Reply #8 on: December 18, 2009, 05:18:33 PM »
I tried the repo moldings about 2 years ago. They were thiner than original and the fit was bad. So unless they have been improved since then, I would'nt recommend them. I repolished the originals. I didn't know about the chrome flash but I think  it will take quite a while for polished stainless steel to oxidize. Especially if you keep after them with metal polish once and a while.
Good Luck
Sam
« Reply #9 on: December 19, 2009, 04:42:52 PM »
It only becomes obvious where you have two pieces next to each other and one is flash-chromed after polishing and the other one isn't - the one that's chromed will maintain kind of an icy-blue appearance in natural light, and the one that's not will eventually take on a slight yellowish cast. If all the adjoining pieces aren't chromed, you probably wouldn't notice it.
« Reply #10 on: December 19, 2009, 07:22:30 PM »
Yup. And you'll find out if you are polishing them and you go through the f. chrome when sanding out imperfections. There is a distinct difference in color.
OBIWAN2T
« Reply #11 on: December 21, 2009, 11:30:04 PM »
Daniel,
         Sorry it took me so long to get back to you.  What I used was #3 soft metal cleaning compound first and then switched to the #5 high gloss polishing compound. Both came from my local Lowes.
Todd
L78 steve
« Reply #12 on: December 26, 2009, 11:48:58 PM »
Flash chrome?  I've been filing ,sanding and polishing SS trim for ages and never seen any evidence of a layer of chrome.  Are you sure about this?
69 Z/28 Dover White. SOLD
« Reply #13 on: December 27, 2009, 01:09:22 AM »
I've sanded some nasty imperfections out and not all showed a color distinction. The ones that did were were indeed a yellowish hue underneath in contrast to the rich bluish overtone they have. Some I hammered out and sanded, beginning with 220 up to 2500, cutting them deeply and did not see a variation.
« Reply #14 on: December 27, 2009, 06:01:51 PM »
Yes. Virtually all GM exterior stainless trim was flash-chromed after polisihing. "Chrome" is clear, and is less than a thousandth of an inch thick. Chrome on bumpers is different - it has nickel underneath it - that's what gives it the silvery look. "Show chrome" (which GM never used) has copper underneath the nickel.
