Author Topic: 1967 LOW FUEL MODULE ? CAN ONE BE REPAIRED ?  (Read 6405 times)
RS3SDL2MG
  • Brad
« on: December 05, 2009, 11:41:06 PM »
my 1967 RS low fuel light stopped working about 7 or 8 year's ago it is something wrong with the low fuel module unit in the back of the console gauges , this part is like $60 buck's plus shipping and I will be honest THAT IS INSANE !
I can't bring myself to buy the part so I am asking WHAT IS WRONG WITH MY ORIGINAL ONE ? and can it be repaired ? I have took the gauge pod off and looked at it you can put 12 volt on the wire going to the dash low fuel light and it come's on so the wire to the bulb is good , what can I do ?
1967 RS 327 (210) horse C-C ermine white 732 bright blue interior RARE 4P - DELETE
big iron
Re: 1967 LOW FUEL MODULE ? CAN ONE BE REPAIRED ?
« Reply #1 on: December 10, 2009, 02:55:28 AM »
Do you have a good ground @ the module? How about the connections @ the gauge (green & pink) ?
If all are good, you may have to bite the bullet, as I do not think the module is repairable.
Bob
RS3SDL2MG
  • Brad
« Reply #2 on: December 27, 2009, 02:48:21 PM »
I've just learned that the fuel module has a FUSE ? or BULB ? in the back of it ? I am going to check that
big iron
« Reply #3 on: December 27, 2009, 06:07:04 PM »
Brad,
Never had a bad module to back door engineer to see what is inside.
Let us know what you find.
Mark
« Reply #4 on: December 27, 2009, 07:33:24 PM »
Theres no fuse, it does have a place for a builb, but its not used on a Camaro.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
RS3SDL2MG
  • Brad
« Reply #5 on: December 27, 2009, 09:34:49 PM »
Quote
As it turned out, the only problem I had was the low fuel module bulb. I did not know that the bulb in the socket served any purpose for the low fuel module.
With the ignition switch on and the Low Fuel light on, I pulled the bulb out of the socket and the ligt went out. I put the bulb back in the socket and the light came on. The bulb does not illuminate, but acts like a connection, I guess.
Can someone explain why GM used a bulb in this module? Or is this just look like a bulb and is not or what?
this guy say's the BULB/FUSE has to be in place for the light to work ?
