Author Topic: 67 front am antenna  (Read 5567 times)
Ron C.
67 front am antenna
« on: December 04, 2009, 01:30:37 AM »
anyone have a pic of a original am antenna for a 67 camaro? Is the base hectagon or round? What does the tip look like? Is the mast round or flat?  ???
RS3SDL2MG
  • Brad
Re: 67 front am antenna
« Reply #1 on: December 05, 2009, 12:58:57 AM »
the rear AM antenna has a oval mast with a tip that has lines on it , the front one's are for AM/FM ?
I know my 67 is listed as having the rear mounted AM only antenna ,
or did they have two different front one's ? an AM front and an AM/FM front ?
1967 RS 327 (210) horse C-C ermine white 732 bright blue interior RARE 4P - DELETE
Ron C.
« Reply #2 on: December 05, 2009, 11:54:09 AM »
I am interested in the front am antenna, mast shape,tip and base. a pic would be worth a thousand words ;D
« Reply #3 on: December 05, 2009, 12:53:15 PM »
Here Ron: http://www.camaros.org/forum/index.php?topic=2036.0
Brad,  the 1967 Cowl Tag Fisher Option Codes tell you what you have. RPO U73 is rear mounted, No S in Group 2 means no rear ant.
RS3SDL2MG
  • Brad
« Reply #4 on: December 05, 2009, 02:31:27 PM »
yep mine has the S and I knew that the rear was AM radio only , but I did not know they had an AM only front ,
I was thinking that if you had a front antenna you had an AM/FM radio ?
« Reply #5 on: December 05, 2009, 03:39:56 PM »
If you just ordered an AM radio (U63), you got a front antenna; same with an AM-FM (U69).
