Author Topic: Rear leaf springs  (Read 4315 times)
red28
Rear leaf springs
« on: December 02, 2009, 09:59:53 PM »
Do I have to remove the gas tank on 1979 Camaro to remove rear springs?  Not much room to access bolts.  Any advise would be much appreciated.
rich69rs
  • LF7/M35/Z22/Z87
Re: Rear leaf springs
« Reply #1 on: December 02, 2009, 10:32:19 PM »
It will be much, much, easier if you do - especially if you are lying on your back with the car on jack stands.
Gas tank isn't hard to take out.  Disconnect the battery, disconnect the ground wire from the sending unit to the body, unplug the wire from the fuel sending unit to the rear wiring harness, near the filler neck.  Disconnect the fuel line from the sending unit line - rubber fuel line hose and a couple of hose clamps.  Unbolt the staps and let her down.  Car needs to be high enough to get the straps pulled back out of the way.  Empty (or near empty gas tank helps as well).  I used my floor jack with a 2' x 2' piece of plywood to help balance the tank as I lowered it down.
Richard Thomas
1969 RS
red28
« Reply #2 on: December 03, 2009, 02:45:51 PM »
Thanks a bunch- probably time to replace rubber lines anyway (30 years is a while)
