Author Topic: 1969 Deluxe Interior window regulators  (Read 7216 times)
epetit
« on: November 29, 2009, 07:56:33 PM »
Hey guys.
In the process of restoration, and thought maybe someone here could tell me what the difference is between a standard and deluxe interior window regulator ?.
My car is coded to have the deluxe interior, but someone has installed the standard door opening mechanizims, and I am not sure if the regulators have been changed. Am I right in thinking that the deluxe regulators would have longer shafts for the window crank to attach too ?. If so, how do I tell what I have currently?.
X66 714
  • Guest
Re: 1969 Deluxe Interior window regulators
« Reply #1 on: November 30, 2009, 12:25:28 AM »
If you have deluxe regulator on standard door panels the handle will be about 1/4-3/8 inch from the std panel....Joe
« Reply #2 on: November 30, 2009, 04:09:39 PM »
The dlx regulator stems have 4 grooves. The std ones have 2 grooves.
epetit
« Reply #3 on: November 30, 2009, 06:26:57 PM »
Thanks guys. I also talked with someone at Rick's and he said that the only difference was the length of the shaft. I asked him to measure one of his reproduced regulators and he said the shaft length was 1  1/4 inches long measured from the bearing housing.
Does this sound right ?
« Reply #4 on: November 30, 2009, 09:30:44 PM »
I'm looking at them, Dlx., 1-3/16"
                             Std., 15/16"
« Reply #5 on: November 30, 2009, 10:48:11 PM »
Here's a pic of an original. Notice the 4 grooves on the stem (shaft). Those indicate the length.
epetit
« Reply #6 on: December 01, 2009, 01:29:41 AM »
Thanks everyone. I now know I have the standard regulators !!!
Thanks again.
