Author Topic: Early 67 Trunk Date code  (Read 4834 times)
MyRed67
  • SZZLN 67
« on: November 25, 2009, 07:17:55 PM »
I got to look at the date code on my original trunk lid today(it has been in storage) the code is T 43.   Some time back I had posted the doors, they are Rt. H 43, and Lft. H 42.   I also found a code stamped in to the outside Pass. side of my Sub-frame when cleaning it up.  I now believe that might also be a Date code, I believe it is I 42.  this stamp is the same size as other Date codes I have found. There is also a larger(1/4")  O R stamped by this code.  Is this probably a Date code?   It is approx. 9" from the rear of the Sub-frame, approx. the middle of the outside of the frame.   Thanks for any input.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
